1978 - 1996 Big Bronco
spindle bolt
Old Nov 13, 2006 | 02:54 PM
69ford99's Avatar
69ford99
spindle bolt
I had to replace the front spindle on my bronco and it has five bolts that bolt the axle or knuckle to the spindle and one of them broke, i'm having trouble finding another one, can I drive it with only 4 bolts for temporary or is that a bad idea?
Old Nov 13, 2006 | 03:19 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Well, I would have to say I wouldnt drive it like that.
I have driven short distances with 4 lug nuts even 3 but that spindil has alot of weght and stress on it and runing it with out all 5 bolts could either bend the flange or snap the other bolts from more stress on them.
That should be a fairly simple bolt to find, if it looks like a regular bolt then get a grade 8 bolt from a hardware store or try the dealer or wrecking yard.
Old Nov 13, 2006 | 03:26 PM
69ford99's Avatar
69ford99
Its dicontinued from ford and none of the local auto stores have it. Its not a hex bolt but it drives in from the back like a wheel stud and its serrated.
Old Nov 13, 2006 | 05:07 PM
topfisherman's Avatar
topfisherman
Best thing to do if you can't find any bolts is to go to a junkyard and pull the front knuckle off a similar truck that is in good condition.
