Sponsored by: Auxito
Torque Pro misfire read
Old Feb 15, 2020 | 07:03 AM
96f150's Avatar
96f150
Forgive me for asking, but im trying to figure out what test to read the PIDs for misfires.......Ive got a small misfire without setting a light and i want to see which cylinder it is....
Thanks
Old Feb 15, 2020 | 08:46 AM
Bluegrass 7's Avatar
Bluegrass 7
Mode 6, Test 53.
Old Feb 15, 2020 | 09:53 PM
truckguy92's Avatar
truckguy92
I use torque lite cause I'm too cheap to pay for the app, I haven't even seen where it'll show misfire. I think I have one when I first start the truck and accelerate in first but it'll go away when it warms up. I plan on doing a complete plug, coil and wire change just to know that's been done as I'm the second owner and doubt the previous owner did it ever.
Old Feb 15, 2020 | 11:17 PM
Bluegrass 7
I'm just suggesting a different thought direction.
What you spend on guessing by throwing parts like this could be better invested to get the program, use it, then know what your chasing over just a feeling that may not pan out.
Said another way, it's diagnostics first then repairs.
Good luck..
Old Feb 16, 2020 | 02:11 AM
96f150's Avatar
96f150
Thanks Bluegrass7
Old Feb 16, 2020 | 02:58 PM
acogoff's Avatar
acogoff
Or what works for me, an Autel al519 will do mode 6 test 53. About $60.
Old Feb 16, 2020 | 03:02 PM
ford390gashog's Avatar
ford390gashog
Pay the 5.99 and get access to mode 6 data. The lite version will not show.
Old Feb 16, 2020 | 03:36 PM
Bluegrass 7
Ok, test 53 will show the stored counts as along as you don't do a clear function.
If a clear is done, several drive cycles may be needed to get a count that is worthwhile and shows a pattern.
This history location does not set a code as it was not given that ability in software.
This history is valuable for picking out what cylinder is causing a misfire under certain conditions such as in OD and light throttle that comes and goes.
Most often this is a faulty coil with 'shorted' turns in it's winding but still works at producing a lower voltage output hence is not a hard failure that produces a misfire code..
Lastly, zero counts is the perfect situation, however no engine will run free of misfire counts all the time due to changing conditions so look for a pattern on a repeated basis over time. This can even suggest a problem or future failure of one cylinder such as the coil or it's boot is leaking from a pin hole or moisture in the plug well.
Like a good Doctor with knowledge and tools to work with, to fix you up.
Your outside and have to look through a window to see what's happening inside.
Good luck.
Old Feb 16, 2020 | 04:25 PM
96f150's Avatar
96f150
BLuegrass, i had high misfire counts on cylinder 5, plug is good and tight, and no moisture in plug well, so i relpaced the coil with an OEM. I keep 3 oem coils in my door pocket...just for special ocassions like this one...lol Ill have to clear the history and run it for a few weeks
Ted928
1997 - 2003 F150
Jul 7, 2019 12:19 PM
hooptytank
Dec 11, 2016 05:57 PM
truckfella
Modular V10 (6.8l)
Dec 1, 2016 06:06 AM
kurboman
Oct 22, 2014 01:16 PM
jorge995
1997 - 2003 F150
Jun 24, 2013 09:26 PM
