Overhead console shorted out
Old Feb 14, 2020 | 04:30 AM
nickdoni's Avatar
nickdoni
Hello all. So my absolute crap recon cab lights have been leaking. My overhead console took on some water and the circuit board shorted or something and the front interior lights dont work now. Anyone know where i can get just the circuit board?
Tks
Old Feb 14, 2020 | 06:33 AM
Heathmc's Avatar
Heathmc
Obviously fix the leak first. After that if the only issue is interior lights I'd probably just live with it... You may be able to order the board from Ford but more likely it'll be the entire console in one piece. I'm unaware of a third party seller with just the board.
Old Feb 14, 2020 | 07:28 AM
Ding126's Avatar
Ding126
Ive read that owners are seeing water issues with the roof antenna and marker lights ….. whats up FORD ??
Old Feb 14, 2020 | 07:53 AM
shawnee1's Avatar
shawnee1
You might find this previous post useful. The circuit board assembly is replaceable.
https://www.ford-trucks.com/forums/1...d-console.html
Old Feb 14, 2020 | 04:49 PM
Section179's Avatar
Section179
You’ll see I made the only useful posts in the linked thread.
f150 part will interchange; that’s what I replaced mine with.
Old Feb 14, 2020 | 07:40 PM
TeddyD's Avatar
TeddyD
I made a post the other day that my truck was leaking from the antenna and the other 3 fords in the shop were checked and had corrosion in their overhead consoles as well. I recommend all owners to check before it’s too late.
Old Feb 25, 2020 | 12:17 PM
nickdoni's Avatar
nickdoni
So the dealer replaced the clearance lights with the new upgraded gasket type. I have the full extended coverage. Now the dealer is saying leaks are not covered and they wont replace the console. This is total BS. Dealer is working with Ford to try and get it approved. Not happy with Ford right now.
Old Feb 25, 2020 | 01:02 PM
Beast2.0's Avatar
Beast2.0
Forgive me but I'm a bit confused. In your first post, you are complaining of absolute crap recon lights leaking. Now you are saying that dealer replaced with new ones? If these were aftermarket lights leaking, how is that Fords problem to fix?
Old Feb 25, 2020 | 02:07 PM
synick17's Avatar
synick17
Trailering
Ebay has a lot of over head consoles from totaled trucks. I just picked one up for $95 dollars to replace the fried circuit board in my truck.
Old Feb 25, 2020 | 02:33 PM
Texas78028's Avatar
Texas78028
I have the ReCon cab lights but I installed them myself and made sure to seal everything properly. I may go back and seal the factory antenna spot as I noticed it only had a gasket with no sealant.
Old Feb 25, 2020 | 06:32 PM
1olddogtwo's Avatar
1olddogtwo
How does aftermarket lights and Ford not covering this........
How are they tied together?
Old Feb 25, 2020 | 07:13 PM
TeddyD's Avatar
TeddyD
In the extra warranty disclaimer, it says water leaks aren’t covered out of the bumper to bumper warranty. My antenna was obviously leaking from day 1 so the dealer said they would fix it under my extra warranty. I was shocked. Of course, I am not going to point out that the warranty states leaks aren’t covered.
No after market accessories installed on my truck that could cause leaks for all of you stating the crappy after market lights leaking comments. It sucks but I agree, if an after market accessory caused a leak, warranty should be denied. Sorry (I am Canadian)
Old Feb 25, 2020 | 07:16 PM
1olddogtwo's Avatar
1olddogtwo
I agree, it no different then a tuner.
Faceplant409
Mar 31, 2018 11:24 PM
ExcursionMan632
Aug 28, 2009 08:37 AM
bignorth
Jan 18, 2007 09:50 AM
cobramustangboy
Electrical Systems/Wiring
Jan 8, 2007 09:09 PM
