DiamondBack internal height measurement pls
Old Feb 25, 2020 | 01:59 PM
waterdownredneck's Avatar
waterdownredneck
Hi all, I have looked all over for this, if any users have a DiamondBack HD or similar model, I'm trying to see how many inches between the truck bed to the bottom of the cover, what's the usable space? I'm assuming it's up to the side rails minus an inch or two but I need an accurate measurement please. Thanks if anyone can help, I have a 2019 short bed Lariat 4x4. Jason.
Old Feb 25, 2020 | 02:55 PM
SARDiverDan's Avatar
SARDiverDan
You will have about 21.5 inches from the raised ridge on the truck bed to the support beam under the cover.
Even though you have "X" amount of space, you can fit some items between the beams if needed. The photo above is from my 19 but the photo below is the HD cover on my 02. If you notice, I have a welding helmet sitting in my tool box that fits between the two support beams when closed.
Old Feb 25, 2020 | 05:55 PM
waterdownredneck
Thanks very much, that’s exactly what I wanted to know, that’s plenty for what I need. I was just days away from putting the deposit on a Leer with the Leer Locker when I saw a SD with the DiamondBack HD. I have never seen one in Ontario before so I called my dealer to change plans, cancel the Leer and find an HD, the folks at DiamondBack have been fantastic. I also found out the internal dimensions for the Leer Locker were 4” too short to hold all my salmon rods broken down, that was the only reason I was going back to a full topper so this was perfect timing.
Is that an insert tray where your helmet is? I was hoping they could make one without the two dividers I see online but I don't think they can, too bad as a my hunting guns would fit nicely in there. I may try to get a customized bin made.
Old Feb 25, 2020 | 05:56 PM
waterdownredneck
Disregard my last question pls., just saw where you said it was your tool box.
Old Feb 25, 2020 | 06:07 PM
Absoluteblack2018's Avatar
Absoluteblack2018
I loved the diamondback HD i had on my old truck. Had that setup for 5 years when i traded it in, worked flawlessly no problems. Ill definitely be picking up one for the new truck soon, 100% worth it.
Old Feb 25, 2020 | 07:40 PM
SARDiverDan
You might look at something like this:
https://decked.com/
Old Feb 25, 2020 | 08:18 PM
ScrapeApe's Avatar
ScrapeApe
I just measured the clearance on my truck with the sprayed in bed liner and the HD Diamondback. When closed, on the side where the locking bar goes under the bed rail, there is 19.5" of clearance. The locking bars slope upwards towards the middle where they connect to the underside of the locking mechanism. Here, there is 21.5" of clearance. I hope this helps.
Harrier
112
Jul 1, 2021 09:19 PM
jriltex
Aug 28, 2020 01:59 PM
truckman5000
Nov 27, 2019 06:57 AM
woody367
Jun 11, 2019 09:47 PM
96sherm
26
Oct 24, 2007 10:58 PM
