I suppose it’s easier during manufacturing to apply the stickers all the same. As mine is stock height with the valance, you need to get down under the truck to even see it. Besides preventing more serious issues (DW) I am trying to take that little shake out of the steering wheel. Going to get back under there today with some spray paint and spray some of the areas that should have been sprayed at the factory that Ford no longer covers. I will probably take it out tomorrow and see how it handles. My Centramatic balancers will be here on Wednesday and then all I am looking at is a better track bar and that will be the completion of my ride improvement/DW prevention plan as I already replaced all the OEM shocks.
When you get the centramatic balancers be sure to post some pictures of them as you install them. Also what part number did you order for the centramatic balancers?
I have 20” wheels as well. I spoke to Hue at Centramatic and he said that they have had some issues with 20” wheels on the new Fords. He said that some fit and others didn’t as specs of the calipers vary. He told me to try the 318 and see if they work and if not, I can get the 328s. The only difference between the two is that the 318 are round and the 328s are more oval shaped to give them a bit more clearance.
I also noticed they don't even show the 328s on their site.
Anyone looking to order the Kelderman dual stabilizer use LST discount code for 10% off. Not sure when it expires. I ordered Saturday 526$ with shipping.
Glad you got it on. So, was it a 10-15 minute install for you like in the video? Took me some time and I put that mounting bracket on several times before I could get it to fit right with the factory bolts. I just need the track bar and mine will be complete. I had to order a torque wrench that would go to 406 ft lbs. as I did not have one.
Probably about a hour or so. Working flat on the ground does slow things down.
