Engine running rough
Old Feb 13, 2020 | 01:15 PM
Jrich21's Avatar
Jrich21
Getting codes 0171, 0174. Replaced both top oxygen sensors, tps, and maf. Replacing the tps seemed to improve idle and performance. Nothing changed with maf. Still running a bit rough at idle and still getting codes. 04 f150 heritage xl
Old Feb 13, 2020 | 02:33 PM
pdqford's Avatar
pdqford
What are the codes?
What did the freeze frame data show?
First SWAG is a vacuum leak.
Old Feb 13, 2020 | 05:54 PM
Jrich21's Avatar
Jrich21
Same codes as before
Old Feb 13, 2020 | 07:36 PM
pdqford's Avatar
pdqford
My bad. You did post the codes.
Is this a 5.4?
Freeze frame data?
Old Feb 14, 2020 | 12:06 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree with vacuum leak being most likely.
Old Feb 14, 2020 | 01:43 AM
Jrich21's Avatar
Jrich21
4.6 no freeze frame data.
Old Feb 14, 2020 | 09:13 AM
F150Torqued's Avatar
F150Torqued
If you have codes, there is (or was) Freeze Frame data. You might have cleared it / not looked for it, but it is stored at the instant a code is recorded. THAT's its purpose, so you can know what various other conditions present that might have lead to the generation of the codes.
Old Feb 15, 2020 | 06:57 AM
96f150's Avatar
96f150
ill second that.....youve got a vacumn leak somewhere. Check pvc hose on back of intake
Old Feb 15, 2020 | 03:32 PM
DBGrif91's Avatar
DBGrif91
More than likely, you’ll end up replacing the intake gaskets and possibly the manifold. It’s not uncommon for the manifold to warp and crack at the seams - smoke testing is a good way to know.
You can start by replacing old vac hoses, making sure the EGR isn’t sticking at idle, and run some seafoam or marvel mystery oil in the fuel to clean the injectors. If it’s due for spark plugs, replace them and the coil boots while you’re at it.
If no improvement, get it smoke tested to find out if it’s just the gaskets or the manifold too.
Old Feb 21, 2020 | 10:54 AM
Jrich21's Avatar
Jrich21
I took battery cable loose and replaced DPFE sensor, almost seems like it made it worse. Getting different codes now though. P2197 ff 01/02 and p2195 ff 02/02
Old Feb 21, 2020 | 10:56 AM
Jrich21's Avatar
Jrich21
Sorry was wrong previously. 04 f150 heritage, 4.2.
Old Feb 25, 2020 | 08:57 AM
Wbruiser2's Avatar
Wbruiser2
I don't know if the OP figured this out yet but I would take the intake manifold off and inspect it. Had a similar issue and once I took it off I found numerous burnt holes like in this picture.
Old Feb 26, 2020 | 02:06 PM
Jrich21's Avatar
Jrich21
Replaced the egr valve. Drove about five miles on the highway. Stopped and went inside, came back an hour later started it up and the service engine light was out. Running good now!
Old May 26, 2020 | 05:59 PM
Jrich21's Avatar
Jrich21
Light back on
Service engine light back on. Same codes 0171 & 0174. Replaced the manifold gaskets and isolator bolts. Runs better but still a little rough at idle and I’m getting 0174. But no more 0171.
Jrich21
1997 - 2003 F150
Feb 14, 2020 05:28 AM
I_run_hills
Modular V8 (4.6L, 5.4L)
Apr 18, 2015 08:33 PM
Fummins
Feb 24, 2015 03:51 PM
RayandTracy
Escape & Escape Hybrid
Aug 9, 2010 08:00 AM
gixxerlance
3.8 & 4.2L V6
Apr 20, 2006 03:55 PM
