Sponsored by: Auxito
Engine running rough
Old Feb 13, 2020 | 01:13 PM
Jrich21's Avatar
Jrich21
Getting codes 0171, 0174. Replaced both top oxygen sensors, tps, and maf. Replacing the tps seemed to improve idle and performance. Nothing changed with maf. Still running a bit rough at idle and still getting codes.
04 f150 heritage xl
Old Feb 13, 2020 | 02:28 PM
pdqford's Avatar
pdqford
What are the codes?
What did the freeze frame data show?
First SWAG is a vacuum leak.
Old Feb 14, 2020 | 12:08 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree with vacuum leak being most likely.
Old Feb 14, 2020 | 02:07 AM
Bluegrass 7's Avatar
Bluegrass 7
Your codes listed tells the story.
The long term fuel tables are shifted rich setting the codes and causing hot rough low speed running and stalling at idle.
Leave the Ox sensors alone. they are only reporting the trouble..
Find / fix the vacuum leak causing the table shifts..
Old Feb 14, 2020 | 05:28 AM
truckguy92's Avatar
truckguy92
What engine? I just fixed mine and should have listened to posters like Bluegrass for example as they were spot on. If it's a V8, check the elbow that comes off the intake near the throttle body if I'm not mistaken. If it's a V6 like mine, you're very likely looking at islolator bolts and intake gaskets, which was my issue. Another possibilty could be the PCV Valve grommet may not be holding the valve in properly which I orginally thought my issue was as mine wasn't installed in the valve cover at all when I looked the engine bay over (the second time).
As mentioned by Bluegrass, the O2 sensors are working fine and have their own code for when they failed or at least my 01 Silverado did. Check over all vacuum lines and fuel filter. Test the fuel pressure as well but be prepared for an intake gasket job. Hope this helps.
Jrich21
2004 - 2008 F150
13
May 26, 2020 05:59 PM
I_run_hills
Modular V8 (4.6L, 5.4L)
Apr 18, 2015 08:33 PM
Fummins
Feb 24, 2015 03:51 PM
RayandTracy
Escape & Escape Hybrid
Aug 9, 2010 08:00 AM
gixxerlance
3.8 & 4.2L V6
Apr 20, 2006 03:55 PM
