Rough idle cold
Old Jan 5, 2015 | 04:58 PM
Fummins's Avatar
Fummins
Rough idle cold
I have a 1992 F150 with a 300/6. On start up, it has a very rough idle and runs rich, and it's seems to be temperature dependant. On a 60 degree day, it may idle rough for 10 seconds. On a 30 degree day it may idle rough for 45 seconds. Definite temperature related. Once it gets past this rough idle, it runs great. The change from rough to smooth is not gradual, it's like flipping a switch. I was expecting the IAC to fix it, but nope. IDEAS??
Old Jan 5, 2015 | 05:55 PM
timbersteel's Avatar
timbersteel
Two sensors I would be inclined to check would be the ECT and then the IAT. They effect startup, idle and drivability. But the problem is intermittent. Pulling codes is suggested and do this on a warm engine. Perform the KOEO test first and post your findings.
Have you checked for vacuum leaks, checked those brittle, prone to crack nylon vacuum lines?
Have you checked the cap and rotor?
Old Jan 7, 2015 | 06:42 AM
Fummins's Avatar
Fummins
Since this problem, I've done a full tune up, including distributor, checked for vacuum leaks, and installed a new computer. It has not been road legal for a few years until now, so I wasn't able to take it anywhere have codes checked, but I will soon. This is an every day problem. Even on a 70 degree day, it idles rough for a short period of time. A 15 degree morning is a 2 minute ordeal... very rich condition. When I replace the IAC, I DID NOT clean out inside the intake. I was just told to check that as well. I will try to check it out and I will post my findings. This truck is barely broken in with 222,000 miles... a part of the family.
Old Jan 15, 2015 | 07:13 PM
Fummins's Avatar
Fummins
OK.. I checked the codes KOEO with the engine warm. I got the following codes: 111, 113, 118, 173, 327, 334, and 543. Also, I recently changed the ECT and the IAT. No change. I removed the AIC and cleaned the intake openings.. all appeared very clean.
IDEAS?
Old Jan 16, 2015 | 12:19 PM
geoffunkel's Avatar
geoffunkel
You've got codes for IAT, ECT, EGR, O2 sensor, etc With that many unrelated codes, I would be looking at the ECM, ECM ground, or the wiring harness to the ECM. I had similar issues rough idle issues on a '91 bronco with the 5.8. Tons of unrelated codes. Turned out the computer was bad, and a new computer fixed everything.
Old Feb 24, 2015 | 03:51 PM
geoffunkel's Avatar
geoffunkel
Any progress on your problem?
hornsurgeon
1997 - 2003 F150
Dec 19, 2010 12:17 AM
ShortboxF150
Aug 31, 2007 03:04 PM
capstan
May 1, 2005 07:20 PM
Burchoid
1983 - 2012 Ranger & B-Series
Apr 14, 2003 12:34 PM
uy7v
13
Feb 28, 2002 11:31 AM
