Best performance
Old Feb 13, 2020 | 06:10 AM
Jesse Mossel's Avatar
Jesse Mossel
Best performance
Looking for best performance exhaust intake chip etc for my F-150 5.4 triton. Any opinions?
Old Feb 13, 2020 | 10:06 AM
WWR's Avatar
WWR
There'll be lots of threads if you search, but we purchased our '08 with a K&N FIPK, MBRP exhaust and SCT tuner.
- I'm not really a believer in air filters or even complete aftermarket intakes actually increasing power, BUT I am a fan of cleaning up the engine bay so I have zero complaints on the K&N setup for that reason alone
-the MBRP exhaust has a decent tone but like all kits was installed marginally well by some owner in his driveway with a basic Harbor Freight socket set. I fully welded one joint to stop a rattle and now I'm happy
-the SCT tuner is allegedly on a "power" tune but honestly I've never once plugged it in to play with it.
Still, I'm impressed with how the truck handles itself in the Colo mountains on 35's with stock 3.55 gearing. I suspect the tune has far and away the biggest impact.
Old Feb 14, 2020 | 02:49 PM
Rumble phish's Avatar
Rumble phish
You're grasping at straws trying to add power with simple CAI kits and cat-back exhausts. Maybe the tuner will give you some benefit, but at what cost? Most of the "bolt on" stuff is just a waste of money.
If you want significant power gains (25-100hp) you'll need to make the motor breath significantly better. This means a full intake, larger throttle body, larger injectors, freer flowing headers and possibly the removal of the catalytic converters (not a good idea).
Depending on the condition of your Triton, you might want to consider a supercharger kit. Edlebrock makes a fairly nice, and complete, kit that should add 100 hp easy. But it ain't cheap!
By far, the simplest "seat of the pants" mod you can make is to swap taller gears, especially if you've slapped on bigger tires.
Old Feb 14, 2020 | 10:07 PM
steve(ill)'s Avatar
steve(ill)
what rumble said !!
08tolleya
Oct 21, 2008 09:25 PM
duxnlabz
1997 - 2003 F150
Jun 2, 2004 02:45 PM
stormyone
Computer Chips & Tuners
Mar 14, 2004 12:30 AM
