Serious knock?
Old Feb 12, 2020 | 03:39 PM
wjwolfe82's Avatar
wjwolfe82
Serious knock?
I've noticed a bit of a knock the last few months on my '69 w/360. I've done plenty of accessory work over the years but don't have much experience with internal engine work. Am hoping someone here can clue me in on whether it's serious or not.
The original owner 'traded' it in to a dealer in PA in 2013. I have a mileage certificate from them and signed by the owner showing 103,000+ miles. I've also talked to the original owner and he says it has never been opened up.
I hope there's enough volume in the video......
https://www.youtube.com/watch?v=7pVn...ature=youtu.be
Old Feb 12, 2020 | 04:25 PM
CougarJohn's Avatar
CougarJohn
Pull the plug wires one by one. See of the knock goes away or diminishes. That indicates pistons or rods or something serious.
Old Feb 13, 2020 | 11:43 AM
fe390pc's Avatar
fe390pc
Follow what John said. Pull plugs one at a time and see if there is a change. Based on the video, it does not sound good.
Old Feb 17, 2020 | 08:39 AM
wjwolfe82's Avatar
wjwolfe82
Thanks for the suggestions. I pulled each plug wire but no change in the sound. Funny thing is that if I put my head over the top of the engine I don't really hear it. I only hear it if I'm standing in front of the motor. It seems most prevalent at the front-driver side.
I'll get it looked at but for now it's stuck in the garage until the threat of road salt is gone.
Old Feb 17, 2020 | 09:12 AM
davelj's Avatar
davelj
How is the oil pressure? You should not have any bearing knock if the oil pressure is good.
It could be fuel pump or timing gear/chain noise. With over 100k on it, I would pull the timing cover and take a look. It could have the original plastic tooth cam gear that is starting to fail.
Old Feb 17, 2020 | 12:04 PM
CougarJohn's Avatar
CougarJohn
Loosen the belts and run it with no acessories spinning. If it goes away itis something driven by belts. Get a 3 foot section of garden hose and put one end to your ear. Start probing acessories, :altrnator, power steering....
Old Feb 17, 2020 | 01:59 PM
351Cleveland C4's Avatar
351Cleveland C4
To me it sounds like it's at half speed. Meaning valve train noise. I would pull valve covers and see if there is any obvious problem with pushrods or rockers
Old Feb 17, 2020 | 07:19 PM
CougarJohn's Avatar
CougarJohn
I think 351 is right. I counted 24 knocks in 6.5 seconds. That comes up to 230 knocks per minute. Double that for crank speed and you get a 460 rpm idle. That is a decent slow idle for this engine.
So the thunks are at valve speed.
You saved a whole lot of money, OP. Do as 351 suggested and pull the valve covers. Look around, you will probably see the problem.
Good catch, 351.
Old Feb 17, 2020 | 07:21 PM
CougarJohn's Avatar
CougarJohn
Or timing chain and fuel pump as Dave suggests. . They run at valve speed. Anyway, probably not rods or pistons.
Old Feb 17, 2020 | 08:48 PM
Christmas's Avatar
Christmas
Not enough video to tell anything. When you rev it up and let the throttle off is there a more noticeable knock? That would be lower end. Does it become more noticeable on RPM increase? Valve train.
Old Feb 18, 2020 | 02:25 PM
wjwolfe82's Avatar
wjwolfe82
CougarJohn, good call w/ the garden hose idea. Though i used a small shop vac hose. It was definitely louder when I pressed the end of the hose to the fuel pump. I got nothing when pressing it against the valve cover or block. Hopefully that's a good sign and all I have is a noisy pump. It is most noticeable when cold. In fact last night I let it run for a good 20 mins or more and it was hardly there after. It does not increase in intensity with more rpm's and oil pressure is good I believe...if the gauge is to be trusted (oil still looks good and no real consumption since change 1000 miles ago). I did previously loosen the belts to check the ps pump & alternator. No problem there.
Though I will certainly pull the valve covers and inspect (need new gaskets anyway), I've got my fingers crossed that it's only the fuel pump.
Thanks to all for the suggestions.
Old Feb 18, 2020 | 06:11 PM
CougarJohn's Avatar
CougarJohn
Change fuel filters and rubber lines when replacing pump.
It will run for a half minute with the pump off from bowl fuel. Maybe you could start it thus to see if the knock is gone.
Just a thought. See what the guys say.
Old Feb 19, 2020 | 07:54 AM
Eric Hamilton's Avatar
Eric Hamilton
I agree with CougarJohn, Replace the filter, hoses, et. and start fresh. If you have the $$, throw in a inline fuel pressure gauge. I'm doing the same to mine so in the future when you have issues you can trouble shoot much faster.
Whitson Metalworks
6.2L V8
Oct 14, 2019 08:45 AM
z 97ford1
1997 - 2003 F150
15
Apr 28, 2012 10:52 PM
jkidd_39
6.4L Power Stroke Diesel
18
Oct 12, 2010 11:31 PM
Danger_Dave
17
Jun 1, 2007 08:01 PM
crawdad
Jan 9, 2006 10:25 PM
