96 E-150 4.9 Not Running
Old Feb 11, 2020 | 05:41 PM
Cascade OR's Avatar
Cascade OR
96 E-150 4.9L 256k Driving out of the garage running fine. Letting idle for a bit, all of a sudden barely idles, doesn't drive. Codes 118 (engine coolant temp sensor) 171 & 174 (system too lean bank 1 and 2) 385 (crankshaft position sensor) 500 (vehicle speed sensor) 1131 & 1151 (O2 sensor, vacuum leak, faulty ignition, fuel injector, ecm) Now won't start. No power on fuel pump, no spark. (fuel pump, coil, and relays for fuel pump and ecm are new or nearly new). No loose/cut wires or bad ground that I found. Removed ecm, did not notice any visual flaws. Anyone have any ideas? How to check ecm? Anything?
Old Feb 15, 2020 | 09:12 AM
Cascade OR's Avatar
Cascade OR
Just a quick follow-up. Decided to spend the money on a "new" ecm from Rock Auto. Arrived yesterday. Plugged in. Started right up.
AeroGuy1212
Aerostar
Jan 4, 2013 04:57 PM
zstangkrewson
Jul 23, 2012 12:25 AM
ampslw
2004 - 2008 F150
Jan 29, 2011 07:17 AM
BLUEOVAL1992
Feb 25, 2010 03:35 AM
idifamilycab
Dec 17, 2007 07:57 PM
