Sponsored by: Kumho
Leaf Spring Part Number Location
Old Feb 10, 2020 | 07:52 PM
DeskDrawer's Avatar
DeskDrawer
I have a 2001 E-350 with the 7.3L SRW, a shuttle bus. I'm planning on replacing the rear leaf springs soon but the vehicle doesn't have the decal on the door jamb with the spring code. Does anyone know if Ford stamps part numbers on leaf springs and if so, where that's typically at? I crawled under the vehicle and could not find any numbers on both springs, but there's plenty or rust in some spots so the part number might be hiding in plain sight.
Old Feb 11, 2020 | 06:59 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
The spring code and/or part number is always great but it can be figured out other ways.
How many leafs does each side have?
Old Feb 11, 2020 | 08:16 PM
DeskDrawer's Avatar
DeskDrawer
The current leaf pack has 9 leaves per side.
Old Feb 12, 2020 | 09:38 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
Perfect! Pretty straight forward then. Your spring is rated for 3,460 lbs Per Side. Here is a link to the specs:
https://www.autoandtrucksprings.com/...pring-43-1085/
We can always price match if you find it somewhere else.
There are other options available like a heavy duty option which is rated for 4,000 lbs Per Side and a Extra Heavy Duty which is rated for 5,000 lbs per side. Unless absolutely needed I would stay away from the 5,000 lb option. It's a great spring but it's pretty heavy.
Old Feb 12, 2020 | 03:49 PM
DeskDrawer's Avatar
DeskDrawer
Got it - thanks ATS!!
Raymond
Jul 11, 2017 03:06 PM
quesey
Jan 25, 2017 06:47 PM
Pele
Dec 31, 2015 06:03 PM
BeachEx
Jan 27, 2014 06:11 PM
mein51
Oct 27, 2007 10:48 PM
