Oil Pan ?
Old Feb 10, 2020 | 10:08 AM
wrongway01's Avatar
wrongway01
Oil Pan ?
I recently bought a 96 F-150 4x4 with a 351 Windsor and automatic trans. Old oil pan looks like it took a rock right in the drain plug area. I have a new oil pan and wondering if it can be replaced without removing the engine. Thanks
Old Feb 10, 2020 | 10:12 AM
GNR22's Avatar
GNR22
It can be done. You'll have to unbolt the motor mounts and pick up the engine to get it out, but you don't have to fully remove the engine.
Old Feb 10, 2020 | 10:40 AM
R&RFord's Avatar
R&RFord
You will have to drop the pan and lift the engine so you can get enough clearance to remove the oil pick up tube, then it will all come out.
Old Feb 10, 2020 | 04:59 PM
timbersteel's Avatar
timbersteel
You will also have to drop the exhaust. The Y-Pipe will be in the way.
szotty
18
Oct 23, 2010 11:23 AM
ramarado
Oct 29, 2007 02:25 AM
rett8799
1997 - 2003 F150
Jan 18, 2005 10:45 PM
T/A Man
Apr 20, 2003 10:10 PM
Ryan50hrl
Mar 7, 2003 07:02 PM
