Replaced ICM today.
When I was driving my 85 e150 it developed a problem where it would not start until I released the ignition switch from the start position. In the crank position the engine would just spin over and not even try to crank. I never traced down the problem because shortly after I parked the van in part because I bought my 88.
I am sure there is a difference in the ignition system between the 85 and 94 but my 85 did have a TFI ignition. My 85 and 88 share the same ignition switch though my 85 is carbed and my 88 is EFI. My 88 and your 94 use the same ignition coil.
My point being perhaps the issue is in the starting circuit. Maybe as simple as one of the contacts in the ignition switch being burnt and not making good contact each time. You would need a diagram for your van to trace down those circuits and get an idea of what to check.
Since the CEL did out while cranking that supposed to mean that the PIP sensor is working.
Since the starting fluid did not work and it runs fine its hard to believe that the fuel pump is the issue and the CEL goes out while cranking wich means the PIP sensor is working and I just replaced the ignition control module.
I replaced the ignition switch a few months ago.
Thanks.
I "am" starting to think it is something of an electrical nature, but I doubt its the the Battery because it cranks really powerful and had the battery tested a few months ago at interstate, although the last interstate I had went bad due to heat, so I was told.
I have a jump starter, next time this happens I am going to hook it up just for the heck of it and see if that changes anything.
Thanks.
https://www.ebay.com/itm/Original-19...QAAOSw2lxfjy0m
Here is an example of what i was saying earlier about the ignition switch. It doesn't have to be in the actual switch though. It could be a connector or something in in one of the ignition components as Spaznaut mentioned.
Of course this diagram below is probably way different from yours but you can see how the green start circuit from the switch pretty much goes straight to the starter relay. So the starter will run no matter what else does or doesn't get power. The red is the second start circuit. that supplies power to the ICM, ECU, and 12V to the coil.
Your 94 uses the same coil as my 1988 so i am going to guess that you have a ballast resistor in your ignition circuit also.. Your starting circuit may not be all that diferent from the older generation vans.
Have you tried giving it a little throttle while cranking when it doesn’t start ?
Remove the ecc computer and check for leaking capacitors !!
Thanks Anna
I did purchase a new computer a while ago but it did not work and I returned it. Maybe I will remove the computer again and take another look at it.
Thanks Steve
