351m Timing
Old Feb 9, 2020 | 10:04 AM
clhale1538's Avatar
clhale1538
Trailering
351m Timing
Hey everybody,
I had the 78 F150 with 351m running, and then I went to fine tune the timing, the timing light read 30 BTDC, so I retarded it and the engine puttered out. Now it won't start, and I can't seem to adjust the distributor to a point where it will start. Any ideas? Thanks all.
Old Feb 9, 2020 | 12:14 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Did you disconnect the vacuum advance, and cap the port at the carburetor / intake, before you checked timing? Was that reading at idle, or was it "total timing"?
Old Feb 9, 2020 | 12:25 PM
clhale1538's Avatar
clhale1538
Trailering
no it was still hooked up, forgot to cap it. Just went through the process of finding tdc again. But now I can’t get it to turn over.
Old Feb 9, 2020 | 01:31 PM
1TonBasecamp's Avatar
1TonBasecamp
Have you turned the distributor all the way back to where it was before?
I've seen it happen before where it's running and then after twisting the distributor to dying, an engine won't start again. Seen it many times in fact, but it's never been satisfactorily explained other than "just one of those odd things" that happens.
No reasonable reason for it not to start after you turn the distributor back, unless you go too far, or not far enough. Could be loaded up with fuel. Could be the distributor body and block bore are dirty, not allowing the distributor to ground well. Could be it overloaded an ignition control module and burned it out. Probably other things as well.
Are you running stock Dura Spark? Or something else?
You need to first verify that you're still seeing a good spark. You can at least get an idea of this with your timing light while cranking. If the light is flashing consistently and evenly while the engine is turning over, re-try advancing it more.
If you've only turned it a little bit, turn it some more even if it's temporarily too far advanced.
Paul
cysneed
Dec 17, 2014 07:42 AM
rbcyouthdude
Feb 15, 2006 10:29 PM
otis348
Oct 8, 2004 10:02 AM
Txquadhunter24
Feb 3, 2003 04:43 PM
