Wipers not working
Old Feb 9, 2020 | 08:47 AM
gg1968's Avatar
gg1968
Wipers not working
I replaced my worn out turn signal assembly. When I first tried the new assembly, my wipers went on about half way, and then quit/stopped. Now they are dead. When I turn them to full on, I can hear a click in the passenger side area behind the dash. All of the fuses are good. My washer is also not pumping, but I can hear a click when pushing in on the wiper stalk.
Old Feb 9, 2020 | 02:31 PM
jas88's Avatar
jas88
You need to tell us what truck you are working on. I am thinking it's an OBS 92-96 truck?
First check to make sure you put the pins back in the spots they belong to in the plug. You did remove the wires from the plug to get them thru the steering column collar, right?
Old Feb 9, 2020 | 04:58 PM
gg1968's Avatar
gg1968
1997 f250. Yes. I removed the collar from the steering column surround trim and unplugged the original assembly. I re-seated the new pin connectors on the new stalk/wiper/turn signal piece.
Old Feb 9, 2020 | 07:32 PM
gg1968's Avatar
gg1968
Yes. I reseated the pins a few times to be sure. Today I turned the wipers to “full on”, (like the fast mode) and they did work. Not the delay settings though.
Bohen
6.7L Power Stroke Diesel
Sep 9, 2019 07:45 PM
rfsdvm
2009 - 2014 F150
Feb 28, 2015 10:54 AM
BCHauler
Oct 19, 2008 03:16 PM
Paul_W
Electrical Systems/Wiring
Dec 29, 2000 09:16 PM
