Windshield Wipers
Old Nov 15, 2000 | 04:47 AM
Paul_W's Avatar
Paul_W
Windshield Wipers
Have a problem with my windshield wipers. When using the wipers for awhile, I go to turn them off, they won't stop unless I turn the truck off and then back on. Then they stop. It will do this only when it is hot weather or the wipers have been used for awhile.
I replaced the wiper switch with no luck. Anyone else have this problem?
Old Nov 18, 2000 | 11:38 AM
shami02's Avatar
shami02
Windshield Wipers
I have a problem that is almost the same with my 1995... If I use the window washer I cannot turn off the wipers without shutting off the truck. My intermittent wiper speeds also do not work at all only high and low speeds. I replaced the switch to no avail, soooooo it must be the w/w motor. Anyone else know of this problem?
Mike
Old Nov 18, 2000 | 10:13 PM
nitro94's Avatar
nitro94
Windshield Wipers
Check the intermittent wiper module.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Dec 8, 2000 | 07:55 PM
fordiesel69's Avatar
fordiesel69
Windshield Wipers
Check the intermittent control module first, than replace the motor. The motor on our 92 bronco did the same thing.
Old Dec 29, 2000 | 04:21 PM
ktorpey's Avatar
ktorpey
Windshield Wipers
I had my 1994 wiper/turn signal switch changed out with a new one. The old one was not working the wipers in the intermitant mode at some levels.
The new one is a updated model and works much better.
Cost was about $100
Old Dec 29, 2000 | 09:16 PM
solidaxle's Avatar
solidaxle
Windshield Wipers
