Came up short...
Old Feb 8, 2020 | 08:19 PM
F-250 restorer's Avatar
F-250 restorer
Came up short...
I changed to different outside tube when I rebuilt my steering column. Everything fit well until I put on the wheel and came up short. There is 3/8" between the back of the steering wheel and the collar or housing that is supposed to meet it. Now there is a gap. I'm scratching my head and can't figure out where it went wrong. I measured the column tubes prior to use, and came up equal.
Any ideas???
Old Feb 8, 2020 | 10:03 PM
John89's Avatar
John89
Maybe a key way, groove, notch, indent or something that is not matched up. Is the outer tube the only change? I bet it is something simple. Take a short break, regroup and then get back at it.
Old Feb 8, 2020 | 11:02 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
I know if you put a 78-79 steering steering wheel on a 73-77 column you get the same results.
Old Feb 9, 2020 | 11:17 AM
F-250 restorer
I slept on the problem and this morning I understood what the problem was. There is a metal collar held on the steering shaft with two set screws. I installed that collar on its witness mark, but I also installed an aftermarket bearing that took the place of the plastic bushing on the end of the column. I think that collar is hitting
the bearing, preventing the shaft from sliding down to where the snap ring at the wheel end is seated. I remember noting that the snap ring is about 3/8" from its normal position. Darn it.
Old Feb 12, 2020 | 06:31 PM
F-250 restorer
See that collar with the two allen head set screws? The original position of that is inside the column tube, out of view. But with the aftermarket replacement bearing in the photo, but with it in place, it prevents the shaft from sliding to the second groove of the snap ring at the wheel end of the column. Yes, there are two snap ring grooves. With the collar outside, I placed the snap ring in the second groove, and the steering wheel was allowed to meet the shifter/horn mechanism housing, without there being a gap between them.
Old Feb 12, 2020 | 06:48 PM
John89's Avatar
John89
So did that fix it? If so, good job.
Old Feb 12, 2020 | 08:11 PM
F-250 restorer
All good now. It is really nice to drive it. I'm glad I by-passed the neutral safety switch and removed it too.
mhu
May 8, 2015 06:14 AM
abyars111
Nov 15, 2013 10:09 PM
ZOOT
Mar 13, 2013 02:08 PM
Pokey11
Jan 28, 2007 08:42 AM
theGman
Mar 2, 2006 10:55 PM
