Sponsored by: Real Truck
hpop Draining
Old Feb 6, 2020 | 02:24 AM
mack279's Avatar
mack279
hpop Draining
Geday f truck Brains Trust.
I come to you from Australia with a question as you are the f truck capital of the world and we had a measly 9000 ford import f trucks. After stolen, wrecked etc there are not many left and even less people who want to know about them, so help is far and wide
I have a 2003 f250 7.3 and it stopped dead on the freeway after the CEL flashed a few times. Had it towed home and started looking around and found HPOP Reservoir was drained. I filled it up but it soon drained again. the oil is draining back to the sump as the oil level on the dipstick keeps rising as I top up the reservoir. The obvious question is is there a simple solution or could this be multiple things causing this problem.
Any help much appreciated before I start to look at this a bit more serious
regards Grant
Old Feb 6, 2020 | 01:57 PM
Just Strokin's Avatar
Just Strokin
I would go ask this question over in the 7.3 forum. You might get an answer or can search for an answer...
https://www.ford-trucks.com/forums/forum31/
Old Feb 6, 2020 | 10:26 PM
metalsmith's Avatar
metalsmith
Yes, check in the 7.3 forum. I have always wondered when you change oil is there a couple liters of oil left in the HPOP. This maybe related.
Old Feb 7, 2020 | 12:56 AM
mack279's Avatar
mack279
Cheers Buddy
Much appreciated
bmc69
Mar 6, 2013 01:04 PM
carltonwebb
Nov 12, 2010 02:26 AM
CCBennett_1
Jul 14, 2010 08:03 AM
mwrike
Nov 30, 2007 07:39 PM
paul100
Jun 30, 2006 09:20 AM
