TREMOR Front Diff performance
Old May 25, 2020 | 09:26 PM
  #61
00t444e's Avatar
00t444e
Originally Posted by ForCal
Thats the beauty of a selectable locker, you disengage it at the push of a button.
Yes but you didn't mention having to run cables, wire or air lines to make it work, they cost more and have more issues, and on the trail you have to keep locking and unlocking them, and hope it engages when you want it to. Auto lockers you just have to install and let it work, not much to go wrong.
Old May 26, 2020 | 07:39 AM
  #62
GNR22's Avatar
GNR22
Thats funny, thats (TFL) who just recently said it was a Torsen like the Raptor. It sounds like they forgot their own facts haha.
And this is exactly why I'm waiting for someone to open one up. I've seen enough TFL videos to know that they don't have much of a clue beyond the "informational sheet" they're reading off of, and doing math for fuel economy.
I would be much less critical of the entire Tremor package if it was indeed a Torsen differential, or was available is more off-road capable configurations (shorter than the CCSB).
Old May 26, 2020 | 08:24 AM
  #63
Drothgeb's Avatar
Drothgeb
I’ve got Trutrac in the front of my Ram. It’s a limited slip, that will lock. I think they are great for a road truck, you don’t notice it until you need it. The truck makes about a 1000 hp and has been used for drag racing, pulling and hauling a camper off-road. After years of abuse, still works great. Only issue is, sometimes while off-road, it may be hard to get it to lock if one wheel has not traction os is in the air. If you do a lot of off-roading a locker may work better. I plan on installing a Trutrac in the front of my non Tremor F350 sometime this summer.
Old May 26, 2020 | 10:05 AM
  #64
willynilly's Avatar
willynilly
how many threads you seen about the rear elocker not working. none that i know of. i would be far more concearned about the vacuum hubs or electric motor on the tcase. reliability seems rock solid on the elockers are far as i can tell
Old May 26, 2020 | 11:29 AM
  #65
00t444e's Avatar
00t444e
I agree with you, the factory e locker is fine since that is what already comes with. Although I still prefer a auto locker in the rear, the e locker isn't much help for street driving. I was talking about when upgrading a vehicle that didnt come with lockers for off-road use I prefer the simplicity and reliability of auto lockers over selecables.
Old May 26, 2020 | 02:35 PM
  #66
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I'd be willing to bet that 90% of the members here have only used their rear locker once or less. Long term use and a high cycle rate reliability are still unknown AFAIK.
Old May 26, 2020 | 03:09 PM
  #67
2020Tremor's Avatar
2020Tremor
I fall into the 10% then, used my locker quite a bit on the 12 F150. Way more than I thought I would. Really nice for pulling the boat out on a slippery ramp without needing to engage 4x4. Spotty ice conditions in town, off-roading in the hills, driving through ditches. My current rig has the G80 and will take a E-locker over it any day. Like being able to control it when needed.
Old May 26, 2020 | 04:59 PM
  #68
2004Limited's Avatar
2004Limited
Yup, how many have really used it to save their a$$?
Old May 27, 2020 | 05:44 AM
  #69
ejb69's Avatar
ejb69
kinda hard to say. Many people that buy 4wd trucks really don’t need them and don’t want to get them dirty or take a chance of putting a scratch in them. That’s not me. A high clearance 4wd is needed to get into where I deer hunt and into my friends remote cabin. I often use the rear locker to launch and retrieve my boat. When I had a truck with out the rear locker I had to use 4wd to get up slick ramps. Get by most of the time with just the locker on now.
so far the Tremor is working out well for me, it seems more capable on the forest roads where my 2016 Fx4 struggled a bit. I just wish I could have gotten the tremor on the super cab as the crew cab is a little longer and harder to get turned around in tight places.
Old May 27, 2020 | 05:52 AM
  #70
BillyE's Avatar
BillyE
I’m not sure what that means. I’ve used it and 4wd at times to keep from getting stuck.
Old May 27, 2020 | 08:39 AM
  #71
2020Tremor's Avatar
2020Tremor
I guess welcome to the 10%. The actual off-road use segment must be small. When I test drove the Tremor the dealer was a little shocked I was more interested in the trail ride vs highway driving. They kept questioning my desire to go off-road, and I would politely reply if I didn’t want to go off-road why spend the extra $ on the Tremor.
Have you looked in to fitting chains on all 4 for snowy/icy conditions on the trails? The Tremor is very close to the same weight as my current rig and chains on all 4s have really saved my butt on those snowy snotty days where weight is not your friend.
Old May 27, 2020 | 10:04 AM
  #72
CJONE's Avatar
CJONE
as was stated, if it requires friction modifier it is the junk clutch pack design. I would not worry about it because if you are a hard user it won't work for long anyway! I have been into a few and won't wast my time anymore trying to get them to last. I use my e locker alot and it has saved me at least 2 times in my 12 150 that I got stuck because I forgot to lock it in. Lock it in and backed out with no issues. Once was deep rutted mud and the other was off camber and lost traction with one front and one rear, locked the rear diff and no drama backed right up. I have used it 4 or 5 times on my 2020 while plowing, normally don't use 4x4 just the e locker. We have guessing 30 3/4 and 1/2 tons with no failures with the e locker or transfercase shift motor. The hubs, not so much a bunch of issues. Glad they have overrides on the super duties. Still have way more issues on the 1/2 tons. A e locker front would be perfect as you could decide when you needed it and not. Unfortunately some people are just rock stupid and would get into or cause a accident and sue ford. I am really surprised one of the vehicle manufactures haven't been sued just because they built a vehicle. It is going to happen!!! A very sad state the human so called race has become. Cj
Old May 27, 2020 | 10:24 AM
  #73
00t444e's Avatar
00t444e
I wonder if it has clutches that tighten up when it slips, similar to how the GM gov lock works or it keeps constant pressure on the clutches like the track lock and most other clutch type limited slips. If it like a normal clutch limited slip that can make for some interesting handling characteristics when driving it the snow and ice.
Old May 28, 2020 | 01:31 PM
  #74
6.2caribou's Avatar
6.2caribou
Put me in the 10% too. My truck has manually operated 4wd. I only leave my hubs locked during our snowy winter season or if I know that I'm going off road and might need 4wd. My E locker rear gets used frequently and often keeps me from having to get out and lock in the hubs.
Old May 28, 2020 | 05:45 PM
  #75
ejb69's Avatar
ejb69
I don’t think there is room for chains on the front of my tremor. I think chains will work on the rear. I have used chains front and rear on my 16 f250. I haven’t tried to put them on the new truck yet. They will probably have to be lengthened to work.
I will likely be adding a winch to my truck. I have been waiting to see what Ford offers. I don’t really need the winch until fall or early winter.
GT4point6
Feb 8, 2020 12:49 PM
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
navifused
Oct 27, 2009 06:36 AM
JASONC
Nov 12, 2003 02:04 PM
fors43
1978 - 1996 Big Bronco
18
Jan 12, 2003 02:11 AM
