Limited Slip???
Old Nov 8, 2003 | 12:44 PM
JASONC's Avatar
JASONC
Limited Slip???
The tag on my diff. reads 3L55 which means limited slip right? Well mine acts like it might as well be an open diff. Any ideas?
I'm running 35 x 12.50's Do you think this is too much for this diff.?
Old Nov 8, 2003 | 01:55 PM
clean79150's Avatar
clean79150
The clutches inside are probably worn out, try adding some limited slip additive, and see if that helps.
Old Nov 10, 2003 | 11:18 AM
lilboysdrivebowties's Avatar
lilboysdrivebowties
i'll try, thanks
Old Nov 12, 2003 | 01:44 PM
Blaine's Avatar
Blaine
I would get the lube evacuated and then add new oil with the limited slip additive.
Old Nov 12, 2003 | 02:04 PM
lilboysdrivebowties
I did. Thanks, I empied it out and filled it back adding the LS add. It works great now. Both tires tearin' it up. I recomend that everyone changes the diff. lube. You would not believe what came out of there. It was bad.... Thanks again
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
navifused
Oct 27, 2009 06:36 AM
Grogtronics
Oil & Lubrication
Sep 9, 2008 08:14 PM
fors43
1978 - 1996 Big Bronco
18
Jan 12, 2003 02:11 AM
nj supercab
Bronco II
Sep 24, 2002 01:15 AM
