Change O2 sensor after 8 years?
Old Feb 1, 2020 | 03:01 PM
cadjak's Avatar
cadjak
1994 E150 Club Wagon, 270K 5.8L. It is running okay but, occasionally it will hiccup for a second or two and then smooth out. I am not getting any check engine light but I am wondering if after 90,000 miles since installing my last O2 sensor, does it makes any sense to just change it out? I think it only has one upstream sensor and I am thinking of replacing it with a NTK 22060.
Old Feb 1, 2020 | 03:06 PM
Conanski's Avatar
Conanski
Yes that would be considered good maintenance, when were the plugs last changed?
Old Feb 1, 2020 | 04:36 PM
cadjak's Avatar
cadjak
Plugs, Ford racing plug wires, cap & rotor. power steering fluid flush, coolant drain & fill, fuel filter, air filter, crankcase breather et al. done 4k ago.
Old Feb 9, 2020 | 03:33 PM
NICKSAN's Avatar
NICKSAN
Ive got 235,xxx on my 94 Club Wagon and the O2 sensor has never been replaced, LOL.
Maybe I should consider changing mine as well, just for routine maintenance, then Ill change it again in another 235,000 miles. LOL.
Old Feb 9, 2020 | 06:55 PM
wirelessengineer's Avatar
wirelessengineer
Yeah, you can't be too careful with that routine maintenance!
Old Feb 11, 2020 | 06:13 AM
dashstiffrod's Avatar
dashstiffrod
I chased an occasional stumble on my '94 5.8 that turned out to be capacitors in the ECM that puked their guts. No codes.
Old Feb 11, 2020 | 09:05 PM
NICKSAN's Avatar
NICKSAN
All kidding aside, the van keeps passing smog every two years so I figure ill just let it be.
Cadjak, dashstiffrod makes a good point. The capacitors on the ECU`s of some 90s era fords go bad. Several years ago I pulled my ECM and replaced a couple bad capacitors, That cured the horrible stumbling issue my van had.
jyarosz
2009 - 2014 F150
Oct 11, 2019 08:21 AM
t.duggan.photo
1997 - 2003 F150
Apr 21, 2011 09:26 AM
nickmobile67
Jun 5, 2004 09:49 PM
kamsho
Jan 20, 2004 04:05 PM
cheesedog1
Aerostar
Aug 27, 2003 09:55 AM
