Sponsored by: Auxito
ABS not working with 35s
Old Jan 30, 2020 | 09:59 PM
jplinville's Avatar
jplinville
1997 F150 XL with 35" tires...
Just received the truck from my son, shipped from SoCal to Ohio. I noticed that the ABS is not working. Could this be due to the oversized tires? Speedo is off due to the tires as well. Will I need to change a VSS gear, or does the computer need flashed to remedy?
Any help is appreciated...
Old Jan 31, 2020 | 01:59 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Computer needs to be told about the current tire size OR tires need to be replaced with factory size.
Either way, ABS should work regardless, so next step would be to scan for codes.
Old Jan 31, 2020 | 03:41 PM
tbear853's Avatar
tbear853
For ABS to kick in requires the brakes be able to almost lock ... or lock a tire.
If the brakes can't almost lock ... or lock a tire … ABS doesn't wake up.
Those 35" tires could just be just a might too much for the truck's brakes or your foot?
Old Jan 31, 2020 | 08:49 PM
pdqford's Avatar
pdqford
Just curious, but what was the clue that the ABS was not working?
Old Feb 2, 2020 | 03:20 AM
jplinville's Avatar
jplinville
I figured it out...the rear ABS wire was pulled tight with the lift. Ill extend the wire on a future warm day
Two clues about the ABS not working...ABS light on and tires locked up on wet roads with moderate pedal pressure.
Old Feb 2, 2020 | 03:21 AM
jplinville's Avatar
jplinville
I still need tovre-gear the VSS...it reads 6mph low at highway speeds.
Old Feb 4, 2020 | 12:08 AM
CathedralCub
FTE Community Team
Reprogram it in the PCM.
1stSD350
Jul 17, 2013 01:10 AM
tenptbuck7mmmag
2004 - 2008 F150
Oct 6, 2006 09:32 PM
mike L
Feb 16, 2006 03:59 PM
Tippy
1997 - 2003 F150
Feb 25, 2005 04:20 PM
adamshee
Jun 14, 2004 10:08 AM
