Sponsored by: Auxito
Flywheel question
Old Feb 3, 2020 | 08:18 AM
bass-n-fire's Avatar
bass-n-fire
Flywheel question
I’m about to swap the 4.6 in my daughters truck. The thing I’m running into is 6 bolt flywheel versus 8 bolt. Is one for an automatic and one for a standard? Or am I off base here. How can I tell which I need before pulling the motor?
Old Feb 3, 2020 | 12:03 PM
pdqford's Avatar
pdqford
The number of flywheel bolts is based on which engine you have.
One is a Windsor engine and one is the Romeo engine.
(And I can’t remember which is which :-(
Maybe bluegrass will jump in here and set us straight.
Old Feb 4, 2020 | 09:43 AM
Bluegrass 7's Avatar
Bluegrass 7
All 5.4L have 8 bolt mounting.
4.6L Romeo (US factory) have 6 bolts, 11 valve cover bolts and main crank bearing jack bolts in the side of the block.
4.6L Windsor (CANDIAN near by just across the line, factory) have 8 bolts and 13 valve cover bolts.
A look at these differences should tell you what you have..
bigwill1767
1997 - 2003 F150
Jan 12, 2017 04:18 PM
stsscott
Nov 6, 2008 09:14 AM
yard_dawg
Sep 28, 2008 01:27 PM
Mid_Mo_F100
Dec 16, 2005 08:32 PM
