Random cylinder contribution codes
Old Jan 28, 2020 | 09:06 PM
Vines1982's Avatar
Vines1982
Bought my first 6.0 power stroke 2 years ago it has ran perfect in August of last year had to replace the head gasket while it was there had them put in head studs when they started it an injector went out then another after replacing 3 of them it is now giving them random cylinder contribution codes can someone please help
Old Jan 29, 2020 | 12:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 6.0L PSD engine forum.
These guys should be able to assist. Good luck!
Old Jan 29, 2020 | 02:20 PM
bigheadwrangler's Avatar
bigheadwrangler
if your FICM is starting to go it'll throw random contribution codes. Do you have a way to monitor your FICM V, sync, ignition?
Old Jan 29, 2020 | 02:37 PM
npccpartsman's Avatar
npccpartsman
It would help if you would post all the codes your getting. I'm not sure it's injectors causing your issue.
Old Jan 30, 2020 | 09:02 AM
Syphlyn's Avatar
Syphlyn
Definitely sounds like a FICM issue or possibly a harness issue.
Are all the codes on one bank?
MStakes
Jul 5, 2014 11:59 AM
Swany89b
Jan 11, 2014 08:33 AM
95schauf
Oct 8, 2012 10:01 AM
kalpesh
Dec 8, 2011 05:06 PM
Talyn
Mar 5, 2010 01:18 PM
