Tiny generators - 800w or less?
I am using a Honda EU2200i mostly these days. Its a fantastic unit - which is why I got it. However, between it and my open frame I end up running the Honda as its quiet and good on fuel. I'm using such low power off it most of the time I hate putting the hours on it. At the same time I can't get by with an inverter because I am pulling more amp hours than I can provide on batteries.
A buddy of mine has the Tailgator generator from Harbor Freight. It seems to work OK - but it is too loud. As for all the other ones out there - I have no experience with them. I have been on job sites where supervisors run the EU1000's out of their trucks, but that is pretty expensive option. Though, as with the EU2200 - maybe that is the smart way to go?
If you do a search around the web you find people using the EU2200's to charge house batteries for off grid living in Alaska. Some of those users claim to have 3000 plus hours on those units. I would say that is very possible of they are maintained properly.
Not sure how many hours you run your EU2200 over the course of a year but 2000 hrs/24 hrs = 83.3 days of continuous runtime. The cost of that unit over the course of it's 2000 hr expected life (assuming you paid the MSRP of $1200) would be $.60 per hour. If you are running it at idle or under a light load I bet you could double the amount of hours before end of life, effectively making it $.30-$.40 per running hour.
Like djousma said above...........don't worry about it just run it and replace it if and when it dies.
Edit: If you really want to geek out on some genset info have a read of post #5 here: https://www.survivalmonkey.com/threa...-cycles.38392/
If my **** was parked on a bike generator I wouldn't get much done... Although I do cycle long distances and the exercise is good, just not convenient when tuned in to different tasks. Going back to the boat example, also, a smaller/lighter unit is that much less in the boat also. Or back of the truck... Or...
Denny
Before that, I had an EM5000SX with over 4K hours that I sold to a buddy who still uses it. Both of them have Commercial Engines on them and they still don't use a drop of oil.
On the other side of the coin, I had a Champion 3500 W that had about 2K hours on it. Still ran, but used a bit of oil and was down on power from when it was new.
If you haven't had a look yet check out post #5 at this site. https://www.survivalmonkey.com/threa...-cycles.38392/
That gentleman has a huge amount of experience with gensets. The amount of hours he claims those small engines will run is very similar to what you stated.
I remember on one of the alaska TV shows there was an old generator that was brought back to life - the size of a car. One of the family's neighbors, had to have been 100 years old or close to it, apparently knew about them so he was recruited to tinker with it. When they got it running the old guy made the comment something to the affect of "Theres nothing I like better than to see these old machines running again".
I can see the point that the guy in the thread made about a lot of those out-post power units being designed to run continuously. It is interesting to me to see the various grades of generators - and if you compare modern units on the current manufacturers lists and their price classes - they really do vary a lot. Though, there is a reason.
Another bit of research I have been doing is in to sailboats. One of these days I plan to get one - not in the cards now though. There are a lot of boats that have inboard motors. In fact, I would say most sail boats over 25' do. Some in that range, and I'd say the majority under about 20', do not - people run outboard kicker motors. Those bigger boat inboard motors are all diesel - from about 8hp on up. The inboard motors aren't just for propulsion (in/out of harbor, when the wind dies, etc) - they also provide a means of charging house batteries, and in some cases you may even be able to get AC power from them (generator heads). The good thing about that type of set up is you have 1 fuel power source burning 1 type of fuel. Though, it is also common for running separate generators so as to have 2 motor sources (redundancy). Then when you look at taking a dinghy along - what do you power the dinghy with? Speaking of fuel and engines that burn it - diesel is by far the most efficient, however aside from a below deck power plant on a boat - none of the other motors (generator, generally speaking, or outboard for the dinghy) burn it = you are forced to carry 2 types of fuel. Not only that, gasoline is much more volatile than diesel = higher fire risk.
Bringing the idea back to generators here - in the case of the sailboat use, specifically, but this goes for any generator use as well - if diesel engines can be so much more efficient, and quieter (lower RPM's than the "screamer" 3600rpm generators, for example) - why are there not more options available? With the sailboat idea in mind - if you are already carrying 100 gallons of diesel why would adding another, say, 20 gallons of gasoline for generator and dinghy fuel make sense? If you had an extra 20 gallons of diesel it could be used for everything - including the boat powerplant if you needed it.
Back in the day (I'm going back about 15-20 years ago now) - when it comes to small engines and repower - Robin an Hatz made diesel equivalents of your usual Techumseh, Briggs, Kohler, and Honda engines - mostly of the horizontal shaft variety. Now days you never see small diesels. In the generator world - there are some like Winco (W6010DE - 5.1kw running) and Generac (XD5000E - same 5kw running class), but until you get to Europe, Asia, and the Pacific Islands - diesel outboard motors don't exist. You would think - especially with all the construction sites, construction companies, and farms in the US that exist on red diesel - there would be more of a demand for a wider range of diesel engines!
On the subject of red diesel - I don't have a place easy to get to that I've found around here to get it. I've filled up jerry cans on my way to my buddy's boat with road diesel. I hate doing it, but it is what it is. I filled up in International Falls, MN one year on my way up North. They have a Holiday station there on rt 53 that has "ethanol free" premium. I was filling up my boat tanks (about 40-50 gallons) and noticed there was a diesel pump there too. I thought I'd fill up the truck at the same time. Nope. Red diesel. First time I've seen that at the pump like that.
I'm sure a lot of it has to do with EPA regulations. However, it's still a PITA.
I've often wondered if it would be within the realm of reason to get a diesel engine from another purpose (tractor, chipper/shreader trailer, etc) and a generator head to make a bigger generator powerplant on a budget. With the same theory - what about those smaller single cylinder Robin and Hatz units - something like that with a generator head in the 4-6kw range might be possible. Though, I don't know that those types of "small" diesel engines are going to have the lifespan of bigger powered equipment motors like off a tractor, etc.
My buddy I sail with has 2 of those same units. That's what got me on to them - we ran them for a ham radio event called Field Day a number of years ago. We sailed up to an island on Lake Erie and set up there. His units are that "original" vintage.
They do not have fuel shut offs. When you turn the dial to shut down the generator the dial cuts the fuel and the spark at the same time.
The one I bought (new in 2019) has a 3 position dial now. Run/fuel on, Fuel Off, and Ignition Off. When you shut it down you turn it to the Fuel Off position - NOT the Ignition Off. This cuts the fuel supply and allows it to "run dry" without running fuel out of the tank, just what is in the carb and what comes out of the short piece of tube from the shut off point to the carb.
Use only 100% gasoline whenever you can. If you run the unit out of fuel just prior to storage and use ethanol free fuel you will not have fuel issues.
I try not to store ethanol free fuel longer than a year. I do have a Honda EMS4500 generator that's 30+ years old that only gets started once or twice a year. Fuel sits in that tank for several years without issues.
http://www.universalweb.com/food/Pony1.jpg
It looks like even the 500w class of generator is hard to come by (the one in the first link I posted in post #6 is discontinued as well).
