E4OD problem
Old Jan 26, 2020 | 06:14 PM
BuckSwank's Avatar
BuckSwank
E4OD problem
97 PSD 4x4 with a E4OD ( approx 40,000 on a rebuild) bw1356 manual transfer case. Shifted into 4lo to climb a steep section of dirt road. Once I shifted back to 2wd, I had to get to 2500 rpm just to creep forward in drive. Shift to 2,1 and reverse, truck moves fine. Truck also moves forward fine in 4hi. with the trans in drive. Trans fluid is at correct level, and appears/smells normal. No flashing od light and no codes stored.
Any ideas before I start taking things apart?
jamesiii1
Sep 6, 2022 04:40 PM
abajc3
Dec 9, 2014 07:01 PM
slave2dafords
Nov 30, 2002 11:26 PM
