1997 E4OD Issues
Old Jan 11, 2018 | 05:25 PM
jamesiii1's Avatar
jamesiii1
1997 E4OD Issues
Bought a 1997 f250 7.3 E4OD trans.
Transmission will barely pull at around 2500rpm. I mean will move the truck an inch or two. Also it still tries to move forward while in reverse and neutral. Any ideas on that to look for in the trans, or any other possibilities.
Old Jan 11, 2018 | 07:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I'd look for another transmission. Running it at 2500 RPM while it is slipping has made sure this transmission is destroyed.
Old Jan 11, 2018 | 10:19 PM
jamesiii1's Avatar
jamesiii1
Is that just clutches welded together or would that it tryed to move forward in N and Reverse indicating other issues
Old Jan 12, 2018 | 06:47 AM
Mark Kovalsky
I think the forward is welded, some others are probably damaged, too.
Old Jan 13, 2018 | 11:52 PM
Azryael's Avatar
Azryael
Where in the world are you? Is your truck 2WD or 4WD?
My old E4OD isn't perfect, but it works a lot better than what you describe.
You can have it if you're close enough to pick it up.
Old Sep 6, 2022 | 04:40 PM
cyanide's Avatar
cyanide
that could be caused by several failures if tries to move foward in reverse my money is on a failed low/rev sprag
Beatertruck
Oct 3, 2011 02:40 PM
fordfan66
Sep 2, 2006 01:34 PM
tonyq
Dec 2, 2004 09:56 AM
1st Alarm
Jul 18, 2003 09:29 PM
kellyb
Jan 8, 2002 01:52 PM
