Fuse box issue
Old Jan 25, 2020 | 11:58 AM
White Eric's Avatar
White Eric
Fuse box issue
I got a Ford F-250 super duty XLT 6.2 l the fuse box under the hood is not giving power to the fuses 1 through 10 the rest of them are getting juice these are my emissions and it is causing me to use 3 times the gas any ideas
Old Jan 25, 2020 | 12:49 PM
crewzer's Avatar
crewzer
Question
A 2017, right?
Check relays #14 and #29? Do they click (audibly and/or by feel) when you turn on the ACC mode or start the engine?
Any (electrical) mods to your truck?
HTH,
Jim / crewzer
Old Feb 14, 2020 | 08:38 PM
White Eric's Avatar
White Eric
Yes I hooked up HID headlights and yes the relays are clicking when turn ignition on.
New issue also I replaced inner lock window module (fuse box) because of water damage everything that was not working before due to fuse box damage works but truck won't turn over battery test 12 volts and ignition dings and dash lit up . Also will turn over at starter but just no crank. Someone said fuel cut off switch any ideas.
Old Feb 15, 2020 | 06:51 PM
White Eric's Avatar
White Eric
Originally Posted by SDcrewzer
A 2017, right?
HTH,
Jim / crewzer
Yes 2017 and yes they click and yes I did just hook up hid headlights. A new issue has came about as well. I just replaced the lock window module (fuse box) do to water damage. I ordered same one used on eBay. Everything that stopped working from damaged box is working now but truck won't turn over. Turn key and dash comes on chime starts but truck does nothing no starter. But I can arc over starter and it will turn over but no crank.
Old Feb 18, 2020 | 01:53 PM
White Eric's Avatar
White Eric
A 2017, right?
HTH,
Jim / crewzer
Edit
Old Feb 18, 2020 | 01:56 PM
White Eric's Avatar
White Eric
Sorry I think I reported you as spam on accident
My bad hope it don't take you off here...
ligito
Electrical Systems/Wiring
Apr 25, 2021 11:58 AM
rigbyrigz
53
Feb 23, 2020 07:41 AM
Crewdcab
Apr 28, 2016 12:01 PM
shortbusted
Jan 9, 2012 04:24 PM
'99-v10-F350
Dec 6, 2010 10:36 PM
