Sponsored by: Real Truck
02 SOF question
Old Jan 24, 2020 | 02:04 PM
1Perry58's Avatar
1Perry58
02 SOF question
I have a 2002 F-350 CCLB 7.3L that has a SOF issue. I don't want to just start throwing parts at it
The actuator motor doesn't move when the switch is changed from 2WD to 4WD high or low.
so far I checked the fuses 17, 19, 28 they are good (wrong size) I don't know which relays ( maybe 40, 41, 42) don't know where to look for them
don't do well trouble shooting electrical problems
I will check the continuity on the back of the switch to see if it is making a circuit thru from ground to each position in the next few minutes and post the results
if anyone has any other suggestions I will appreciate it
Thanks in advance for any and all help!!!
Old Jan 25, 2020 | 07:46 AM
the_old_ranger's Avatar
the_old_ranger
What's a SOF.?
Old Jan 25, 2020 | 11:01 AM
1Perry58's Avatar
1Perry58
shift on the fly
its the type that is electronic
Old Jan 25, 2020 | 05:02 PM
the_old_ranger
OH! I get it! S=shift O=ON! and F= Fly ok sorry about that. Any luck with it yet? Well, just seat of the pants having never been there and done that , can you get someone to work the switchj while you get under the truck with a voltmeter? It has to have a relay somewhere also I guess I would go there next.
Old Jan 25, 2020 | 06:18 PM
1Perry58's Avatar
1Perry58
So far I have no voltage at the actuator and no voltage at the switch? kinda confused
Old Jan 26, 2020 | 11:53 AM
the_old_ranger
Without seeing a wiring diagram I don't know how to advise. You have to find where supply voltage comes from.
dustylee
Jan 31, 2015 01:45 AM
wickedklown83
1997 - 2003 F150
Aug 27, 2012 06:17 AM
F350Greg
Nov 11, 2009 12:43 PM
mudmaker
May 11, 2008 10:51 AM
gzimmer
Aug 15, 2005 05:19 PM
