Understanding the early 6.7 valve cracking problems
Old Jan 23, 2020 | 10:30 AM
speakerfritz's Avatar
speakerfritz
a lot of folks incorrectly believe the early 6.7 cracked cable problem is caused by broken glow plugs. As explained in this video, broken glow plugs and cracked valves are two different problems.
https://www.youtube.com/watch?v=_FBg4UIeCMQ
Old Jan 23, 2020 | 10:32 AM
speakerfritz
Old Jan 23, 2020 | 10:45 AM
ford390gashog's Avatar
ford390gashog
The valve failure only affects the sodium filled valves in the chassis cabs trucks.
Old Jan 23, 2020 | 11:12 AM
Just Strokin's Avatar
Just Strokin
The trucks sold before April 2010 had exhaust seat problems. The exhaust seats would "fall out" of the heads. This would cause the valve warping or valve failure. To prevent the dealer from spending hours tearing the engine down, they determined a quick check was to inspect the tips of the glow plugs. If damaged, then they concluded the valve seats failed. If not damaged, then they would have to disassemble the engine to determine the problem.
By now, most of those engines should have exhibited the failure if they were going to fail and have been fixed
Old Jan 23, 2020 | 12:16 PM
djousma's Avatar
djousma
Not to argue, Larry, but I believe that it was trucks with a "build date" prior to 3/11 that were a part of the valve problem. See this reference post. Actually, that entire thread is about this issue.
Old Jan 23, 2020 | 12:25 PM
Just Strokin
Dave, you are probably correct....I use the April date since my old brain slips the cogs at times...lol
Old Jan 23, 2020 | 12:37 PM
speakerfritz
There are glow plug tip break off problems and there are cracked valve problems with no damage to glow plugs.
The cracked valve problem was predominantly on the passenger side cylinder heads .
Old Jan 23, 2020 | 03:11 PM
Just Strokin
The glow plug tips were never an issue unless there was a valve damage.
The passenger side is the side the PCM/ECM controlled the extra fuel flow to perform a regen. It was the only side that dumped extra fuel for regen. I am not sure as I have never got any clarification if Ford changed this strategy in later updates/engines.
Greg Ogdan
Jun 20, 2019 07:42 AM
F350-6
Dec 21, 2016 07:36 PM
bobv60
6.7L Power Stroke Diesel
Oct 25, 2016 02:22 PM
F250_6.7
Jan 15, 2016 05:49 AM
LGMOUTH
16
Nov 28, 2007 03:52 PM
