first time ford build
Old Jan 22, 2020 | 05:24 PM
Jon Greenway's Avatar
Jon Greenway
I am working on my first ford. It is a 1971 f100 custom. I am pulling the 240 6 out and replacing with a 302 and am planning on using the original 3.03 tranny. my question is can i go to the junk yard and pull the clutch and flywheel from a later model say something out of the 80's or 90's and make it work. Thank yall for all the information and posts on here.
Old Jan 22, 2020 | 06:23 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
I am no expert but I think the 302 uses 2 different balance weights through the years so you will need the right weight for the year 302 you have.
On the 3.03 trans you may want to look into a 5 speed w/over drive like the M5-R2 from the 80's trucks or maybe a WC T5.
I think you will have a much better driving pleasure with either trans over that old 3.03
Dave ----
Old Feb 20, 2020 | 06:29 PM
Jon Greenway
thanks for the input ill look into what my local junkyard has available. Just wondering why the 3.03 is inferior I have never driven one.
Old Feb 20, 2020 | 06:42 PM
85e150's Avatar
85e150
The 3.03 is a great 3 speed transmission. Having had one for years, I was pleased at the improvement when I swapped in a 4 speed. Later on I had a couple vehicles with 5 speeds. Ahh, much better.
If you are going to the trouble to upgrade, bring along a gearbox upgrade as well. JMO.....
BTW the balancer break on the 302 is 1981. See if you can find a later Mustang or Explorer roller motor.
Old Feb 23, 2020 | 11:00 AM
Jon Greenway
The 302 that i am swapping in is out of a 83 ltd crown vic. would these have came with roller motors
v2addict
Nov 26, 2012 04:19 AM
Jumpdummy
Mar 3, 2012 06:40 AM
Hickfied
Engine Swaps
Jul 30, 2008 12:47 PM
hippyman01
Jan 19, 2006 09:48 PM
Low Six
May 8, 2002 02:38 PM
