Leveling Kit Questions - 2019 F350 CCLB
So I have a few questions regarding leveling my truck. When I got rid of my 2011 F350 I actually had a Readylift 2.5" kit new in the box (States its for 2017+). I never installed it on my truck.
My goal is I want to ride the truck as good if not better than stock with a little bit bigger tire. I don't go offroad very often, mostly logging roads.
So my plan is for now:
- Install the 2.5" Leveling Kit - https://www.readylift.com/2-5-front-...2011-2018.html (Owned)
- Install either BDS or Readylift Track bar bracket - https://www.stage3motorsports.com/BD...r-Bracket.html
- Install Adjustable track bar - https://www.stage3motorsports.com/12...Track-Bar.html
- Install Carli or Moog Caster Bushings - https://carlisuspension.com/product/...rection-shims/
- Install Carli Tuned fox shocks - https://carlisuspension.com/product/...shock-package/
My questions are:
- Do you need a track bar drop bracket with an adjustable track bar?
- Is it better to do the radius arm drop brackets (BDS) or caster bushings?
- Am I Missing anythings?
Last truck I leveled was my 2006 CCLB and i didn't have any of the extra parts, just the pucks and upgraded shocks.
Thank you!
My questions are:
Thank you!
I installed the Readylift 2.5 this past weekend that included the track bar bracket. I have the new caster bushings but haven't installed them yet. I also have the Fox BDS 2.0 shocks installed. I don't know if you need the bracket if you have the adjustable track bar. I can tell you that after 200 miles on mine with the 2.5 in place, no shims, and no front-end alignment yet, it drives exactly like stock; no change in steering feedback and tracks as straight as an arrow.
The BDS radius arms look sweet but a bit more money than caster bushings. If they accomplish the same thing, I suppose only your wallet can answer that question.
If you watch the Moostang video on Youtube, you won't miss anything. The only thing I found is that you will have to bend up the tab on the brake-line extension brackets to get it to line up with the frame. But that only takes some pliers or a soft tap with a hammer. I also reversed the track bar bolt so the nut is on the front of the bracket. That way, I can get a torque wrench on it more easily if I ever need to re-torque it.
I will take the bushings with me when I get my front end aligned and see what happens. But with my (limited experience) with this kit, I don't foresee needing anything else. Good luck with your project and post up your findings.
I installed the Readylift 2.5 this past weekend that included the trackbar bracket. I have the new caster bushings but haven't installed them yet. I also have the Fox BDS 2.0 shocks installed. I don't know if you need the bracket if you have the adjustable track bar. I can tell you that after 200 miles on mine withe the 2.5 in place, no shims, and no front-end alignment yet, it drives exactly like stock. No change in steering feedback and tracks as straight as an arrow.
Get the OUO radius arm drop brackets. Moves the axle back to its original location. Caster bushings wont fix that.
https://www.ford-trucks.com/forums/1...tor-shims.html
You don't need a track bar bracket if you run the carli adjustable track bar.
+1 on the OUO radius arm drop bracket. It provides more geometry correction than just caster. It lowers the radius arm to be level again, reducing bump feedback, and moves the axle forward closer to where it once was.
I have a gasser coming so I had to piece together a list. The carli track bar and OUO radius arm drop brackets are a must. A Readylift by itself would work but why reuse the problematic OEM track bar and why guess at caster when you can just install brackets and get so much more.
Are you going to get a steering stabilizer? The OEMs seem to also be problematic and on national backorder. That's the one thing I haven't decided on. It will be a carli because it's geometry correcting and adjustable or I'll go dual PMF with Foxes. No having to mess with N2, better than OEM geometry but more costly.
Thank you for the advice. Yes I will do a dual stabilizer at the same time. Likely the BDS or the Rough Country kit. I figure it’s good insurance.
Inked Painter
2017+ Super Duty
29
02-19-2019 12:54 PM
LaredoF350
1999 to 2016 Super Duty
03-01-2011 10:05 PM
DeerSniper
05-08-2004 08:38 PM
