Sponsored by: Real Truck
track bar relocation bracket
Old Dec 9, 2011 | 07:48 AM
stumpbuster's Avatar
stumpbuster
since my leveling kit install, d/s tires stick out an inch or two more than the p/s. the track bar brkt evidently fixes this.
Ford Miscellaneous - 2005-2007 Ford F250/F350 4wd - Track bar bracket 2" to 2.5" by Tuff Country # 22971
any one use this or a similar bracket?
it doesnt really bother me now the way the truck sits, so ya think its ok if i dont get one?
thawts appreciated
Old Dec 9, 2011 | 04:20 PM
SuperDutyScaler's Avatar
SuperDutyScaler
you should buy an adjustible tract bar, this way the alligment shop can get your front axle back to center where it should be. if you leave it that way it will be putting huge amounts of pressure on the brackets wearing them out fast, plus the bushings in the control arms will be pushing side ways from it. all in all no i wouldnt leave it like that on my truck but its not my truck so...
Old Dec 9, 2011 | 04:27 PM
SuperDutyScaler
05-09 Ford F250/F350 Super Duty Adjustable Track Bar (for 2.5-9" of lift) @Top Gun Customz
KLM Performance Inc. - Online Store for KLMPerformance.com - Ford Pan Rod Bars
What WOBBLE?
this last ones fixes the death wobble plus its adjustible
Old Dec 11, 2011 | 08:47 AM
stumpbuster
but wouldnt the brkt do serve the same purpose but jus for ahelluvalot cheaper
Old Dec 11, 2011 | 09:44 AM
Firefighter 1406's Avatar
Firefighter 1406
I have the same problem stumpbuster, but mine sticks out more on the drivers side. I would like to fix this too.
Old Dec 11, 2011 | 07:53 PM
SuperDutyScaler
yes and no, it will help but you'll never get the axle centered right. dependingon engineweight, front springs etc the axle will always be off some with just a drop bracket. thats why the adjustible bars are soooo much better. my dads 2000 F350 was pulled to the drivers side after the level springs were put on, after a few years the springs settled and now its off to the passenger side now. so when i put new springs under it this summer i also installed a zone adjustible tract bar so we had it alligned and now its perfectly centered under the truck. I also did this on my 2004 F350 and its now centered also. Before my dads 2000 was all over the road and i say its because of the axle being off center causing a crab walk effect, now its straight again with no weird road manners.
Snowman 8
Jul 19, 2019 09:26 PM
bigjeezy86
Jan 21, 2018 10:56 PM
Yahiko
Jul 11, 2012 03:58 PM
Boss_hoss
Apr 4, 2011 04:03 PM
Robert6401
Aug 27, 2005 03:54 AM
