NP-203 input bearing replace
Old Jan 17, 2020 | 07:37 PM
Olblack's Avatar
Olblack
I have a 1976 F-250 , 390, automatic, full time 4x4. The input yoke into the transfer case is loose and seal is leaking. Was wondering what all was involved in replacing the seal n probably bearing I suspect. Thanks
Old Jan 17, 2020 | 09:18 PM
mark a.'s Avatar
mark a.
Did you check to see if the yoke nut is loose ?
Old Jan 19, 2020 | 09:32 AM
Olblack's Avatar
Olblack
Not yet. The seal is bad also. So thought I would change out the bearing too if it was just taking off the front cone while I had the drive line off .Does the cone serve as the retainer to hold the bearing in ? The schematics show a clip or snap ring there also. And does anyone happen to know the correct bearing, seal n gasket part number? Thanks
pezsox
13
Apr 2, 2017 01:42 AM
joeycyph56
Aug 21, 2016 09:38 PM
78longbed
Nov 10, 2008 09:24 AM
LonnieD
1978 - 1996 Big Bronco
Jun 13, 2007 10:31 PM
bremen242
Oct 1, 2003 09:38 AM
