Safe to cut out uppies with a sawzall??
#31
I just crank the WG actuator rod all the way down. Then use compressed air and blow gun to use the actuator to push rod out while you hook it up.
Welding is not required. You can tap and plug both holes. Plugging the EBPV solenoid back in on DIY delete means no codes.
mcali2
16
06-15-2017 09:37 AM
diehardstroker
25
09-30-2013 04:16 PM
DieselBeast01
20
12-20-2008 10:39 PM
mybigredford
04-09-2008 11:20 AM
