Last summer my A/c was hitting new lows of 43 degrees with the ball valve mod. Currently I have a leak on the low pressure side taking me down to 0 psi and blowing 103. I’m trying to figure out my next move here without taking it in to a shop of course.
Also would like to see the worst case parts list which I think would be
compressor
dryer
orfice tube
condenser
Please let me know if there are other parts that should be replaced when they system is open. Thanks
It's a Ford, the only way to get it right is to replace the entire thing: compressor dryer
orifice tube condenser
evaporator
When dealing with old green, all of this was replaced along with all the lines and blower motor, and resistor. You don't want to mess around in South Texas.
My 1st “overhaul” omitted new hoses and I was back in there a year later with a clogged orifice, despite a thorough flush. You might as well get hoses too.
If the system is empty the next step is performing a leak check. I use Nitrogen, but a case can be made for using shop air. Pressurize it to 150psi and look for leaks. Rubber lines, Condenser, Compressor, service ports and connections are the common spots. Look for oily/dirty spots on the aforementioned items and start there with soapy water in a spray bottle for a leak detector. I also use a stethoscope to listen for leaks.
If you are doing 'Worst case scenario' I would add flexible lines and Evaporator if your keeping the truck. Might as well have 100% new system, right? It will work better and you should get at least another 10 years on the rubber lines.
compressor
dryer
orfice tube
condenser
reality check, that is your best case scenario as it is assuming the refrigerant leaked out of one of those components, need to find the source of the leak and gix that plus those items and while not a must, seems a bit foolish not to replace lines that are also near the end of their service life while the system is opened or you would end up repeating the process sooner then you like.
@RigCity I agree with the others in that you should do a complete system replacement. I used the following components when I did mine May 2019. They seem to be holding up well.
Once you have reassembled the system and completely evacuated it, be sure to use a scale to weigh how much refrigerant you put back in. The correct amount is 42 oz per this chart: https://www.techchoiceparts.com/refr...rd-light-truck
