Gauges only work when you push unlock
Old Jan 16, 2020 | 05:16 PM
itsnotanova's Avatar
itsnotanova
I have a 2000 f350 kicking my butt. The gauges only work when you push the unlock button. I have a few parts trucks I've used parts from to test different items. So far I've replaced the GEM/fuse panel, headlight switch, relays, cluster and radio from other trucks with nothing fixing the problem. I've checked and cleaned the grounds under the dash. I've also run wire from the battery ground to the body and frame. I'm not having any luck finding a wiring diagram for my year truck. The one in the tech folder is for a 2002 and the other link connecting to BBB doesn't work. I'd like to ground the cluster, but I don't know which wire is the ground
Old Jan 16, 2020 | 06:25 PM
Hootr's Avatar
Hootr
This is from my 2001 manual. May or may not be the same as 2000. Hope it helps.
Ground G300 is located in LH driver side kick panel.
Old Jan 16, 2020 | 07:17 PM
itsnotanova
Thanks. I new the black wire was a ground but didn't know if there were others. It looks like the PK/OG is too
Old Jan 16, 2020 | 07:28 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
One thing you could check is the wiring bundle going into the drivers door from the cab. I had some very strange issues going on and that bundle had bare wires on them creating the problems. Re-wrapped the wires and used new wire loom and all the problems went away.
Just a thought! Good luck......
Old Jan 17, 2020 | 06:53 PM
itsnotanova
The pink with orange ground wire isn't connected. I bypassed it and the gauges started working. I need to trace trace where it's not connected or permanently bypass it. Thanks for the help guys
Old Jan 18, 2020 | 07:12 AM
FordTruckNoob's Avatar
FordTruckNoob
@itsnotanova Here is the diagram for the 2000 model year. It appears to be identical to the one @Hootr posted.
What did you do when you say you bypassed the PK/OG wire? Leaving a factory ground wire disconnected is usually not the best thing to do. Your original issue with gauges working only when the unlock button is pressed may be back-driving the gauge cluster, indicative of a short, or possibly something worse.
Old Jan 18, 2020 | 01:22 PM
itsnotanova
I ran a grounded wire to the back of the cluster where the PK/OG wire gores into and the cluster started to work. I need to trace that PK/OG wire and see why it's not grounding
Old Jan 18, 2020 | 01:25 PM
itsnotanova
I ran across another thread where a guy was having the same exact problems I was having. His ended up being a bad body ground. I checked all of those grounds and even added more grounds just to eliminate the body or frame grounds as the cause.
elkycali
16
Apr 25, 2019 07:32 PM
7oldblue3
Mar 18, 2019 05:17 AM
wjstarck
Jun 24, 2018 02:00 PM
grinnergetter
Oct 12, 2011 09:53 PM
Rude1
1997 - 2003 F150
Nov 9, 2003 01:24 AM
