I have a 1996 f350 7.3l powerstroke with a e40d automatic 4x4 transmission. I bought this truck in September of 2019 the previous owner ran the transmission hot on temp gauge not sure how hot.. When I got the truck it ran fine, then all of a sudden I went out to warm up the truck as usual and about 15 mins later I went to leave as I put the truck in reverse it started to rough idle and then stalled out I restarted the truck and it was fine later that day after work the same thing happened. Shortly after I lost drive gear I can put truck in 2nd gear than shift into drive and it'll be fine but as soon as I stop I have to drop it back into 2nd. I changed out the neutral safety, the solenoid pack and new filter due to the filter not being plugged in when I dropped the pan. If anyone can help I would greatly appreciate it
I don't have a check engine light on so I did not check I was under the impression that you could only check for codes if there is a check engine light
