MANUAL TRANSMISSION
Old Jan 15, 2020 | 11:33 AM
Budro574's Avatar
Budro574
MANUAL TRANSMISSION
Hey everybody,
1959 F100 with the OG y block and ford o matic. I'm installing a Mustang 2 front end. I'd like to go to a manual transmission. There's a brake/clutch set up for sale online. The gentleman selling it is willing to throw in the hydraulic master for a bit more scratch. What else would I need for a T5? I'm probably going to find a 302 to go with it. The y is tired, leaks, and stinks up the interior of the cab (crankcase fumes). I like the y block, but this is a daily driver, so reliability is key. Efficiency comes second. Y block is failing on both accounts.
Would the original clutch pedal/cylinder work with a t5?
Old Jan 15, 2020 | 05:44 PM
85e150's Avatar
85e150
Your '59 should have a hydraulic clutch. ( Edit ?)
IF you can adapt a hydraulic slave to your new bell, you are in business.
I thought the usualy Mustang/T5 set up was a cable pull clutch?
Might take some fiddling, but I think you can make hydraulic work.
Edit: See post 3 and OP, There is a Ford-o-matic in the truck--'59s came with hydraulic clutches if manual trans equipped. OP could adapt one.
Old Jan 15, 2020 | 06:08 PM
JohnNewb's Avatar
JohnNewb
Says he has a Fordomatic.
Old Jan 15, 2020 | 06:14 PM
85e150's Avatar
85e150
Uhhh....missed/forgot/brain poofed that one. Thanks.
Old Jan 16, 2020 | 02:04 PM
spurredon's Avatar
spurredon
Would you need a cross member?
Old Jan 17, 2020 | 08:51 AM
kenny nunez's Avatar
kenny nunez
Clutch linkage
The hydraulic master cylinder on that vintage was cast iron and just like the brake master cylinder were prone to leak internally, the clutch would engage while the clutch pedal was still down. Not fun at a traffic light. I can remember changing them back in the day.
The best and simplest is with a hydraulic throw out bearing and master cylinder kit. The 97 and up Ford trucks used that system and should be easy to adapt. You will have to experiment with the clutch pedal rod to get the correct stroke so as to not “bottom out” the master cylinder.
Adding the swing pedal is easy and you will not need an equalizer spring.
Vintagerestoration
Jan 21, 2019 09:55 PM
Codelizard
Escape & Escape Hybrid
Nov 11, 2018 09:23 PM
skipr
Nov 15, 2009 10:02 AM
OH_VDUB
Apr 15, 2007 02:53 PM
73stallion
Nov 14, 2006 03:30 PM
