Modded B spring hitting exhaust help!
Old Jan 24, 2020 | 05:10 PM
BoulderX's Avatar
BoulderX
Excursion V & B code spring and other parts needed ?
where can I find the part numbers, brand specs, for the following on the Excursion V and B code mod:
I am making a list and will publish when I have all the details.
- 2" hanger for the V code ( brand and specs, part number ?)
- F350 rear block for the mod B code : this correct ? F81Z-5598-GA " 4" F350 block ?
- Front U bolt for V code : F81Z-5705-ZA ?
- Rear U bolt for mod B code so fits with extra 2 leafs ?: F81Z-5705-EA ?
- Rear B code 3C3Z-5560-CB or is it the 3C3Z-5560-CA with overload spring and extra block, will that give more room for the Ex springs you add ???
- Track Bar to ensure front V codes and adjust to center ( brand, part number, specs ?) ?
Old Jan 27, 2020 | 07:53 PM
Lee Mitchell's Avatar
Lee Mitchell
Updated picture
Here is how my ex is sitting.
I love the stance and the ride.
Old Jan 27, 2020 | 08:26 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
nice, love me a good junk yard build.
Old Jan 27, 2020 | 10:43 PM
Jregezeino's Avatar
Jregezeino
Looks real sharp! These springs make it handle like a whole new rig.
Old Jan 30, 2020 | 08:36 PM
BoulderX's Avatar
BoulderX
Did you also use 2" hanger with the V code and the F350 block with the Mod B ?
Old Jan 31, 2020 | 03:00 PM
Jregezeino's Avatar
Jregezeino
Negative. That may induce a nose high situation again, sits with a nice rake not using those hangers.
Would probably be close to level with those if that’s what you’re after.
Old Jan 31, 2020 | 03:04 PM
BoulderX's Avatar
BoulderX
So what did you swap on it ? V, Mod B, is that it ? no 2" hanger, no f350 block ? I am trying to figure it out. what size wheels/tires is your ride now ? would 33" tires clear ?
Old Jan 31, 2020 | 04:32 PM
Jregezeino's Avatar
Jregezeino
I ended up with X/modB and 4” Tapered F350 blocks in the rear. Stock hangers. Running 285/75/16 tires, yes 33s would fit with ease.
Old Jan 31, 2020 | 05:17 PM
BoulderX's Avatar
BoulderX
did you do Ford OEM V and B ? trying to decide to do that or find others on SDtrucksprings, and not sure about getting used at Junk yard .... might have to replace bushings and stuff ?
Old Feb 1, 2020 | 12:06 AM
Jregezeino's Avatar
Jregezeino
Talk to Junior at ATS, he will get you set up. I would avoid used springs, new ones are only 90$ each, not worth saving 200$ and having old stuff to me..
Old Feb 1, 2020 | 09:09 AM
pirate4x4_camo
FTE Remembers
used springs can be gold or junk, if you have the time you can build a high quality leaf pack.
A used Ford oem spring that is not sagged is gold, i will even say it will be better then a brand new aftermarket spring.
a sagged spring is a time waster as you will need to go out and find another one that isnt sagged.
hlozano
Jul 3, 2018 06:12 PM
Dereck
Jun 29, 2013 03:12 PM
Spyderjohn
Jun 15, 2011 02:53 PM
billygoat
Mar 11, 2008 10:34 AM
