Different trims, different redlines 7.3?
Old Jan 14, 2020 | 12:49 PM
FordExpy486's Avatar
FordExpy486
Anyone know why the new 7.3 Gas V8 has a redline of 5,500 RPM in a regular XLT or Lariat truck but the redline for this same engine is at 6,000 RPM on the Tremor? Also it seems the XLT shifts sooner where the Tremor revs right out to just about 6 grand before an up-shift. The power ratings are supposedly the same so why the difference in max revs? Gearing dependent? The actual clusters read 500 RPM different where the red starts as well.
Old Jan 14, 2020 | 01:19 PM
640 CI Aluminum FORD's Avatar
I wonder if its tuned and mapped differently out of the factory. I remember once driving a 2005 FX4 5.4L F-150 back to back with a 2005 5.4L XLT F-150 and the FX4 felt so much more lively than the XLT. But in that case it could have been gearing, I think it was 3.55 vs 3.73's in the FX4 if I remember correctly.
Old Jan 14, 2020 | 03:30 PM
FordExpy486
Likely was gearing, an 05 would have been the 4R70 transmission so rear end ratio would make a difference. The later 5.4 motors that came hooked up to the 6R80 were peppier and 3.55 highway cruiser gearing was more tolerable. As far as I know all those engines had the same redline unlike this situation.
I don’t know why 3.55 are even offered on this engine, it should be 3.73 standard and then optional 4.30 much like the 6.2 gas job. The large gap in ratios has me perplexed when a 3.73 is a happy medium if you will.
Old Jan 14, 2020 | 07:19 PM
ncl's Avatar
ncl
I bet one gear ratio will be going away. Ford is probably seeing what the take rate is of ratios and will stop offering 3. Will probably end up being 3.55 and 4.30. At least they better keep 4.30
Old Jan 14, 2020 | 08:47 PM
bryced15's Avatar
bryced15
I found several 7.3L non tremor 4.30 trucks with a 6,000 redline, but also found non tremor 4.30’s with a 5,500 redline. Only difference was that the 6,000 redline trucks have the upgraded gauge cluster with the bigger productivity screen. I know... that doesn’t make a lick of sense. A truck’s redline doesn’t change based on a fancier gauge cluster... I also found 3.55 and 3.73 7.3L trucks with the 5,500 redlines and 6,000 redlines with the gauge cluster being the only difference.
In this video, it looks like it reaches redline in 4 out of the first 6 gears.
Old Jan 14, 2020 | 08:53 PM
Mkos1980's Avatar
Mkos1980
Same issue with the 6.2s. I made a post late last year about this as well. Gearing had nothing to do with it.
Old Jan 14, 2020 | 10:42 PM
FordExpy486
The 6.2s all run right up to 6 grand from what I’ve seen.
Bananasfoster
Mar 8, 2021 07:16 AM
tnslick
General Diesel Discussion
Jun 20, 2008 10:10 AM
trux4me
2004 - 2008 F150
16
Apr 24, 2006 09:50 AM
grippper
1997 - 2003 F150
Feb 13, 2006 08:46 PM
philips
Feb 24, 2004 06:58 PM
