General Diesel Discussion
Changing gear ratio?
Old May 28, 2008 | 02:29 PM
tnslick's Avatar
tnslick
I have a F-350 dually with a 7.3 powerstroke engine and was thinking about changing my gears. I have 4:10 gears now and can get gears rated at around 3:55 to go back into it. Has anyone done this? If so how much fuel mileage if any can I gain by doing this? I know I will lose some power, but i do not pull as much as I did once anyway and I have some to spare anyway. I also get about 13 to 14 mpg now and was hoping this would help. the one thing i notice now is that when we do go on trips that when I am running out on the interstate around 75 to 80 mph that the rpms are 2700 or more. I have been told that 3:55 would drop that down to maybe around 2100 rpms at them speeds. Just looking for some better fuel mileage and any help is wanted! Thanks
Old May 28, 2008 | 04:57 PM
rbaker6336's Avatar
rbaker6336
I think 3.73 would be about the highest feasable gear
Old May 30, 2008 | 12:13 AM
phill1060's Avatar
phill1060
I was just talking to a guy that has a 7.3 and had 4.10 in his truck. He switched to 3.55 and he said it was the best thing he ever did to it. He said on his last trip he was averaging 22mpg. just FYI
Old Jun 4, 2008 | 03:35 PM
cartmanea's Avatar
cartmanea
Wind resistance goes up at the square of velocity, power required from your engine goes up at the cube of velocity. Slowing down will make a huge difference in mileage, so if you can keep it around 65 that would help a lot. Also, 2700 rpms is way over the peak torque of the 7.3, so thats not an efficient place to run it. Peak torque is around 1600-1700 rpms, so the optimum gear ratio for running 75-80 as you listed above would be under 3.0, which don't exist. Changing to 3.55s would really hurt your low end power, but if you don't tow much it may not be an issue. 3.73s would be only a 10% change, so your 2700 rpms would come down to around 2430 rpms.
The gear change would help, but you'll see a bigger improvement by slowing down. I ran 80 all the time when I had my Intrepid, but now that I'm in a truck I set the cruise at 65-70.
Old Jun 17, 2008 | 07:52 PM
deereman4020's Avatar
deereman4020
my $.02 i'd go for it if you only tow every now and then and what you tow isn't very heavy. besides if you get the knowledge you might be able to change ratios in a day by your self. might want to look for 3.42 gears. and by the way if you are thinking of changing ratios by your self i would buy an old ford dana 60 axle and practice taking the ring gear out. Just a thought.
Old Jun 20, 2008 | 10:10 AM
bushpilot's Avatar
bushpilot
in the OBS trucks they had a 3.55 dont know if it was an option or not but friend of mine has it...
cwheeler96
Jun 27, 2014 07:46 PM
Macrobb
Jan 12, 2012 09:34 AM
Nightrain
16
Aug 17, 2006 01:56 PM
dwagner
2004 - 2008 F150
Jul 10, 2005 10:45 PM
chipper
Mar 23, 2005 06:34 PM
