Transmission Problems
Old Jan 24, 2020 | 03:56 PM
FSA's Avatar
FSA
I thought that as well, in regards to the trans slip.
i just got off work and currently have accelerator pedal position, vehicle speed, gear commanded by module, torque converter slip(actual), torque converter clutch(modulated), torque converter clutch(actual), SS 1-3.
Old Jan 24, 2020 | 04:07 PM
FSA's Avatar
FSA
This is everything transmission related I can watch
-coast clutch solenoid control
-electronic pressure control?
-gear commanded by module
-lowest idle throttle position?
-net engine torque?
-overdrive cancel switch/hold switch
-shift indicator light
-shift solenoid 1,2,3
-speed control actuator switch coast
-speed control actuator switch off
-speed control actuator switch on
-speed control actuator switch resume
-speed control actuator switch set/accel
-speed control input switch
-speed control no switch input
-throttle position input
-throttle position mode
-throttle position sensor status
-torque converter clutch-actual
-torque converter clutch-modulated
-torque converter slip-actual
-transmission control indicator light
-transmission range
-transmission range sensor-volts
-unlock convertor for traction control
-vehicle speed
i don’t know which of these actually work for our trucks
Old Jan 24, 2020 | 06:13 PM
FSA's Avatar
FSA
This is from a stop going to 68 mph. Excuse the commentary.
top left- accelerator pedal position
top middle- VSS
top right-torque converter slip-actual
middle left- transmission range
middle middle- torque converter clutch-actual
middle right- gear commanded by module
bottom left- SS 1
bottom middle- SS 2
bottom right- SS 3
Old Jan 24, 2020 | 07:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That shows that the shift solenoids are being commanded correctly. It doesn't show if that signal gets to the trans or not, the PCM doesn't know that.
throttle position and vehicle speed work, as do the shift solenoid commands. The torque converter, range, and commanded gear are not working, the data doesn't make sense.
Old Jan 24, 2020 | 07:14 PM
FSA's Avatar
FSA
Okay, so what does that mean lol. What do I need to rest next?
Old Jan 24, 2020 | 07:26 PM
Mark Kovalsky
This is what you need to do next:
Originally Posted by Mark Kovalsky
What you describe is what happens if the shift solenoids are not getting power. That's where you should start looking. See if the red wires on the transmission connector (passenger side of the trans) have +12 volts with the key on.
Old Jan 24, 2020 | 08:26 PM
FSA's Avatar
FSA
I will do that tomorrow, is there a scanner you recommend for the E4od?
Old Jan 24, 2020 | 09:23 PM
Mark Kovalsky
There is no scanner for the E4OD. You need one that can talk to the PCM.1997 diesels were a strange breed. I think Forscan can do it. You can download it free from www.forscan.org. You'll need an ELM327 adapter to connect it to the truck.
Old Jan 25, 2020 | 12:33 PM
FSA's Avatar
FSA
The red wires are getting 1.4v with KOEO, what now? I appreciate all you help Mark.
Old Jan 25, 2020 | 12:38 PM
Mark Kovalsky
Trace those circuits to find out why they are not getting 12 volts.
Old Jan 25, 2020 | 01:06 PM
FSA's Avatar
FSA
From what I could tell the wiring for the transmission lines up to these two plugs. The circular plug, red wire has 12 V.
i went back to the transmission after that and now I have a dilemma. When I test the red wires on the trans harness and ground to the frame/a bolt I get 1.5V. When I do the same wires but ground to my electric fuel pump I get 12.8 volts. How is this possible? Is the frame/bolt a bad ground and not showing what the power wires are actually getting?
TwoToneBullnose
Jun 1, 2020 07:59 AM
Jake9473
13
Nov 7, 2014 09:34 AM
Franko72
582
Sep 25, 2010 04:23 PM
mrmilkme
Jan 19, 2005 07:04 PM
bluesoftail
Nov 24, 2003 07:18 PM
