Parting out 2 ford trucks let me know what you need boonville ny
91 f150 runs and drives frame is broke by the steering box cab is in pretty good shape box is nice other then wheel wells. Nice hood and tailgate also. 302 auto 4wd nice red power interior
89 f150 straight 6 auto 2wd runs and drives bottom of cab isnt horrible but the top is rotted above windshield fenders amd doors are good box is useable has a couple holes. Nice grey interior
need the froint fneder to raDIATOR SUPPORT BRACES (BOTH SIDES) ALSO THE BODY FILLER PANEL (STONE DEFLECTOR WITH SEALS ATTACHED) lASTLY7, THE PLASTIC PIECE THAT MOUNTS ACRTOSS THE FENDERS AND RADIATOR SUPPORT UNDER THE HOOD
i have all of that but i have to check to see how nice the filler panel is
Does the '91 have cruise control and does it work? If so, how much for all cruise control components and cruise control steering wheel shipped to Laurel, MS 39443?
Hi there, I'm looking for the rear fender well chrome moldings (both sides or whatever you have) in perfect or near perfect shape... do you have those available?
I'm not sure if you want to do this to the trucks yet depending on far you are in the parting off process.
But I need the midship tank cross member that bolts to the frame rails, the tank straps tie into.
Specifically the rear crossmember, I need that angled bracket off of the crossmember.
Here is a link to a picture of what I need, post #7.
Being that we both are in rust belt, it might not be worth your effort either.
