Radius Arm Drop Brackets vs Castor Shims
Old Jan 18, 2020 | 10:18 AM
  #31
PENOBSCOT's Avatar
PENOBSCOT
Originally Posted by Badford
I have the ready lift leveling kit which rides just like stock. I have not had it aligned yet. It drove straight after I installed the kit and still does with the new drop brackets. I will probably get it aligned before I buy new larger tires. Overall very pleased with the quality of Ready lift, Kelderman and OUO products. Just under $1000 for everything. Kelderman SS was the most expensive....
Thank you for posting your install pictures, it looks good. Are the radius arms parallel with the ground now and have you noticed if it took the bend out of the front spring?
Old Jan 18, 2020 | 06:01 PM
  #32
homerj's Avatar
homerj
im assuming you bought the ones that move the axle forward 3/16 and not 1/2 ?
Old Jan 18, 2020 | 06:52 PM
  #33
Daniel Reinard's Avatar
Daniel Reinard
I have seen on FB where someone used the .500" brackets and didn't do anything else to the suspension. He said he didn't have any issues. I dunno about that. OUO engineers them and he seems to know his stuff.
Here is some communication with OUO when I asked the difference between the two brackets and if I needed sway bar relocation parts.
"Yes, you get 2 brackets, and the hardware in the photo with the 105040 or the 105070.
105070 2.5D Radius Arm Drop Standard - Radius Arm Drops
The 105040 is if you are going to run tires bigger than 35’s. Moving the axle forward 1/2” gets you room between the fender and the tire. You can run our bumper spacer
101360 - 1/4" to 3/4" Thick Front Bumper Stackable Spacer Kit - 2017 and Newer Super Duty.
They will be on the web store soon, But you can put them in the special instruction in the cart on the webstore and we will add them to the order.
These Sway bar links work will with the 105040 and will be on the web store soon, But you can put them in the special instruction in the cart on the webstore and we will add them to the order.
These links keep the Drag Link and sway bar clearance correct.
#105060 Front Sway Bar Axle Adapters with 6.5in Sway Bar Links for F250 F350 Superduty
We try to make your truck last longer with less problems than other companies.
We are more functional detail oriented, not many others even understand what bump steer is let alone how to build suspension without it."
Old Jan 18, 2020 | 07:12 PM
  #34
Badford's Avatar
Badford
My brackets moved the axle 3/16.
Old Jan 21, 2020 | 10:28 AM
  #35
CBEllis's Avatar
CBEllis
Badford - how was the install? What did you attach the ratchet to when you pulled the axle forward (i assume)? Did you use any other support for the frame or axle or can these drop brackets be installed with the truck on the ground? I may be buying a set of these soon. CB
Old Jan 21, 2020 | 12:48 PM
  #36
Badford's Avatar
Badford
I had my truck on a lift. You could do it on the floor with a floor jack. Make sure you can raise and lower the truck with a floor jack on the frame not the axle. There are holes in the radius arms that I put the S hooks in and found some holes in the frame to pull it with. Pass side I had to pull the axle back, dr side was the opposite. I left my wheels on. With the weight off the wheels the arms want to raise up. With a little pressure on the wheels they will drop down out of your way to install the brackets. Also get some loctite for the bolts that don't have lock nuts.
Old Jan 21, 2020 | 02:33 PM
  #37
BocaIvan's Avatar
BocaIvan
Is the idea with these brackets that the caster shims are not needed anymore?
Did you have to install the sway bar relocation bracket? Or are the sway bar brackets that came with the readylift kit enough?
Old Jan 21, 2020 | 02:46 PM
  #38
Badford's Avatar
Badford
With the drop brackets you should not need the caster bushing. I only have the sway bar drop brackets that came with my RL kit.
  #39
CBEllis's Avatar
CBEllis
my kit came with drop brackets for the sway bar (readylift) and my caster is in the mid 2’s on both sides - 2.3 drivers side and 2.6 passenger side. I am thinking that these brackets would put me in the mid 4’s which would be best case (for me).
Old Jan 21, 2020 | 02:54 PM
  #40
CBEllis's Avatar
CBEllis
What about a realignment? If my alignment is solid now, will I need another after the drop bracket install? Is it a drastic change?
Old Jan 21, 2020 | 03:04 PM
  #41
Badford's Avatar
Badford
Mine has a slight pull to the left now. I plan to get it aligned before I put new 35" tires on.
Old Jan 21, 2020 | 03:29 PM
  #42
camxracer's Avatar
camxracer
So, it sounds like the best scenario is to install the radius arm drop brackets and not install the shims? I still have the shims in a box so I can return them if the drop brackets are a better solution. And do the radius arm drop brackets negate the need for the Readylift sway bar drop brackets? This thread is getting really interesting.
Old Jan 21, 2020 | 03:58 PM
  #43
Badford's Avatar
Badford
You will still need the sway bar drop brackets from Ready lift. Those are two different issues. I would keep the caster bushing till after you have it aligned. Depending on how big you go on tires. Every alignment shop seams to have there own specs. If they say you don't need them great send them back.
Old Jan 30, 2020 | 01:34 PM
  #44
CBEllis's Avatar
CBEllis
Badford: So it's been a week. How's the drive with the OUO drop brackets?
Old Jan 30, 2020 | 01:36 PM
  #45
speakerfritz's Avatar
speakerfritz
yes,inquiring minds would like to know.
