remote entry
Old Jan 9, 2020 | 04:40 PM
Bonanza35's Avatar
Bonanza35
remote entry
Has any buddy reprogrammed new remote key flob? Just wondering, I bought two new ones off amazon for the son's truck. Need to program them. Thank you in advance.
Old Jan 9, 2020 | 04:47 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Yes!
@brian42 created a thread called something along the lines of "did you know" which gives detailed instructions on how to program a new FOB.
It might be in the Tech folder as well, but I cannot remember for sure. If it isn't, please post what you find here and I will include it.
EDIT: The thread is there: https://www.ford-trucks.com/forums/attachment.php?attachmentid=265183&d=1564431165
Old Jan 9, 2020 | 04:56 PM
Colorado350's Avatar
Colorado350
Hey Chet, This video worked for me before I got the remote start installed.
Old Jan 10, 2020 | 09:50 AM
brian42's Avatar
brian42
Veteran: Navy
Program Keyless Entry/Remote:
Notes:
- All locks must be up or down to start.
- You can only program up to 4 units max.
- If you do this procedure it resets the unit so you must program all the remotes every time you do this.
1. Insert your key in the ignition and turn from OFF to ON eight (8) times in rapid succession with the eighth turn ending in the ON position.
2. The doors will lock/unlock to confirm that the programming mode has been entered.
3. Within 20 seconds, program a remote transmitter by pressing any button on the remote transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated)
4. Repeat step 3 to program additional remote transmitters. The doors will lock/unlock for each remote transmitter to confirm that it has been programmed.
5. When you have completed programming the remote transmitters, turn the ignition to OFF or wait 20 seconds. The doors will lock/unlock to confirm that the programming has been completed.
SPECIAL NOTE: if you didn’t get a fob when you bought your truck you probably don’t have keyless entry if it’s an XL, you might have it if you have an XLT, and you probably have it if you have a Lariat (or above). Perform step 1. If step 2 happens then you have keyless entry. You can buy fobs for about $10 on Amazon, slap a 2032 battery in there, and program it.
It's from this thread that has other truck tidbits in it: https://www.ford-trucks.com/forums/1...k-nuggets.html
Old Jan 20, 2020 | 06:14 PM
Bonanza35's Avatar
Bonanza35
Hey guys just wanted to report back on this. Thanks alot for this information. I haven't done this yet, it was for my sons truck. I bought two fobs off ebay for him but haven't gone over there to do this. God bless, and thanks for the help!
davidkstyler
Feb 3, 2023 11:48 AM
brandon.edwards
Mar 10, 2014 12:01 AM
johnsjsj
Jul 23, 2010 03:14 PM
Rico
Dec 6, 2009 02:58 PM
RadarG
Escape & Escape Hybrid
Aug 21, 2007 02:25 PM
