Intake suggestions?
Old Jan 9, 2020 | 07:06 AM
joe blow's Avatar
joe blow
I made a few passes after the truck had come to operating temperature as I was monitoring IA1 ( off the MAF ) and the air temp was not much warmer than the ambient temp outside the truck.
Originally Posted by Yahiko
You will be pulling heated air from under the hood if I am recalling the correct intake.
Old Jan 9, 2020 | 12:49 PM
Amicus's Avatar
Amicus
Originally Posted by SmackDaddy
Even with the S&B I was getting the filter minder light on the cluster so I removed the lexan cover and drilled a bunch of 5/8” holes in a grid and covered it with some fiberglass core nylon coated solar screen to maintain flow while keeping leaves out when I open the hood.
You can see it in this photo
Engine looks very nice. Did you paint the CAC tubes or buy them?
Old Jan 9, 2020 | 02:26 PM
SmackDaddy's Avatar
SmackDaddy
I powdercoated CAC pipes, FICM bracket and air intake elbow. Paint doesn’t hold up, been there, done that and wasted time and money.
Kingkoopa
13
Feb 5, 2014 07:01 PM
F-250 Super Duty
Mar 26, 2013 08:23 PM
Forced347sn95
May 19, 2005 10:17 AM
dannunz
Mar 22, 2005 06:34 PM
1990Fordf150v8
Sep 17, 2003 03:44 PM
