air intake upgrade ????
Old Mar 21, 2005 | 08:04 PM
dannunz's Avatar
dannunz
hi all just thinking about upgrading my air intake. do you think the banks power pack with k and n fillter (uses existing air intake) is better then the afe magnum force and the mac intake system.
thanks gabe
Old Mar 21, 2005 | 08:14 PM
Robbgt's Avatar
Robbgt
thanks gabe
Personaly, I would save the cash and go "home-made tymar" a.k.a Kwikk Filter mod.... looks like this, cost 35 bucks, and took 15 min to build, Use (1) NAPA part # FIL6637, and then if the truck is pre-97 you might need a coupling and a piece of PVC like i did.... good luck
Old Mar 21, 2005 | 08:31 PM
dannunz's Avatar
dannunz
robb did you see much of a differance after doing the mod.
gabe
Old Mar 21, 2005 | 08:44 PM
Robbgt's Avatar
Robbgt
To be honest with you, it won't make a big difference unless you have a chip, upgraded injectors, or a bigger turbo. BUT! It will keep the dust from getting to your turbo, and the turbo sounds awsome!! maby a little faster spooling turbo but thats about it... since my rig only has a few low budget mods (listed in sig) it doesn't do to much, but it sounds good and gets a few cool points !!
-Robb
Old Mar 22, 2005 | 08:02 AM
mainecorrado's Avatar
mainecorrado
will that napa filter work on my 03 F250?? looks good and would be a lot less than the K&N setup.
Old Mar 22, 2005 | 08:21 AM
Robbgt's Avatar
Robbgt
Yes it will!! And you won't need all that extra crap that I have on mine since yours is a superduty, just pick up the filter, and slip it on over your intake boot (snug fit) you may need a new clamp, get something heavy duty and remmember not to use any lube on the hose or filter to get it on there. Then Drive it like you stole it!!
-Robb
Old Mar 22, 2005 | 11:47 AM
mainecorrado
what about the air flow meter thing? can i just unplug it, or leave it plugged in and just hang it somewhere.
Old Mar 22, 2005 | 06:34 PM
Robbgt's Avatar
Robbgt
i just zip-tied mine to the side of the finder well, on the newer trucks like ur 02 i think you could zip tie it near the master cylender if you wanted to, where ever is fine.
dieselsmoker
6.4L Power Stroke Diesel
Jun 17, 2013 07:12 PM
DrewE05
Air Intakes, Air Filters & Ram Air
36
Feb 18, 2013 09:04 PM
grishw1
Jun 14, 2012 01:53 PM
WillGray
2009 - 2014 F150
15
Sep 3, 2011 06:59 PM
vent
1983 - 2012 Ranger & B-Series
Feb 8, 2010 10:40 AM
