Acc position question
Old Jan 6, 2020 | 09:27 PM
SwampRattFord's Avatar
SwampRattFord
Question Acc position question
When my key is turned to the Acc position my alt and oil pressure light comes on. Is that proper for a 66?
Thanks,
Old Jan 6, 2020 | 11:30 PM
Christmas's Avatar
Christmas
My 66 does to, seems normal. Would not work out to swift while trying to get lucky on a date with the radio on. I guess you could call it the red light district.
Old Jan 7, 2020 | 04:24 AM
Crop Duster's Avatar
Crop Duster
It's worse than just those two lights burning. Apparently Ford didn't think ACC was going to be used much because on ACC everything except the ignition circuit has power on it. The biggest draw is the field circuit for the ALT. Turn it on ACC for 15 minutes and put your hand on the voltage regulator an ALT. they will be quite warm.
Old Jan 7, 2020 | 05:16 AM
User 71024's Avatar
User 71024
Put everything on your RUN terminal, then just wire what you want on acc. directly to the acc. terminal. IF you think it's too much load for the ignition switch use a relay.
Eric
cadougherty_67
Sep 23, 2019 12:04 AM
packrat56
Sep 22, 2014 01:03 AM
86LariatXLT
Apr 27, 2013 07:30 PM
"Beemer Nut"
Electrical Systems/Wiring
Nov 16, 2004 01:18 AM
Dan76'F100
May 15, 2003 10:12 PM
